Data SheetADL5506TYPICAL PERFORMANCE CHARACTERISTICS VPOS = 3 V, TA = +25°C (black), +85°C (red), 0°C (green), and −40°C (dark blue) where appropriate. CFLT = open, unless otherwise noted. Input RF signal is a sine wave (CW), unless otherwise indicated. Error referred to slope and intercept at indicated calibration points at 25°C. Power referenced to 50 Ω source and with a 52.3 Ω shunt matching resistor on the board. Distribution plots based upon more than 50 devices. 1.11.030MHz–5dBm50MHz1.0100MHz0.9450MHz0.9900MHz0.81900MHz–15dBm0.82140MHz 2700MHz0.7E (V)E (V)G3500MHz0.7A4500MHzG 0.6A–25dBmLT OLT0.6O 0.5T V UT V0.5U 0.4–35dBmTPTPOU 0.4OU 0.3–45dBm0.30.20.20.10.10–50–40–30–20–10010 003 101001000 006 PIN (dBm) 1768- 1 FREQUENCY (MHz) 1768- 1 Figure 3. Typical VLOG vs. PIN over Frequency at 25°C Figure 6. Typical VLOG vs. Frequency for Five RF Input Levels at 25°C 5.56VPOS = 2.5VVPOS = 2.5V AT –40°CVPOS = 5.0V AT –40°CVPOS = 3.0V5VPOS = 2.5V AT +25°CVPOS = 5.0V AT +25°CVPOS = 5.0VVPOS = 2.5V AT +85°CVPOS = 5.0V AT +85°C5.0VPOS = 5.5V4VPOS = 3.0V AT –40°CVPOS = 5.5V AT –40°CVPOS = 3.0V AT +25°CVPOS = 5.5V AT +25°C3VPOS = 3.0V AT +85°CVPOS = 5.5V AT +85°CmA) 4.5(2NTB)1d4.0R (0CURRE YRRO–1LEPP 3.5–2SU–33.0–4THREE-POINT CALIBRATION AT–5–40dBm, –30dBm, AND –10dBm 2.7V, 3V, AND 3.3V ON TOP OF EACH OTHER2.5–6–40–20020406080100120 004 –50–45–40–35–30–25–20–15–10–505 007 TEMPERATURE (°C) 1768- P 1 IN (dBm) 1768- 1 Figure 4. Quiescent Supply Current vs. Temperature, 2.5 V to 5.5 V Supply Figure 7. Log Conformance Error vs. PIN over Supply Voltage and Voltage Temperature at 100 MHz 66VPOS = 2.5V AT –40°CVPOS = 5.0V AT –40°CVPOS = 2.5V AT –40°CVPOS = 5.0V AT –40°C5VPOS = 2.5V AT +25°CVPOS = 5.0V AT +25°C5VPOS = 2.5V AT +25°CVPOS = 5.0V AT +25°CVPOS = 2.5V AT +85°CVPOS = 5.0V AT +85°CVPOS = 2.5V AT +85°CVPOS = 5.0V AT +85°C4VPOS = 3.0V AT –40°CVPOS = 5.5V AT –40°C4VPOS = 3.0V AT –40°CVPOS = 5.5V AT –40°CVPOS = 3.0V AT +25°CVPOS = 5.5V AT +25°CVPOS = 3.0V AT +25°CVPOS = 5.5V AT +25°C3V3POS = 3.0V AT +85°CVPOS = 5.5V AT +85°CVPOS = 3.0V AT +85°CVPOS = 5.5V AT +85°C22B)1B)d1dR (0R (0RRO–1RRO–1EE–2–2–3–3–4–4THREE-POINT CALIBRATION ATTHREE-POINT CALIBRATION AT–5–40dBm, –30dBm, AND –10dBm–5–40dBm, –30dBm, AND –10dBm2.7V, 3V, AND 3.3V ON TOP OF EACH OTHER2.7V, 3V, AND 3.3V ON TOP OF EACH OTHER–6–6–50–45–40–35–30–25–20–15–10–505–50–45–40–35–30–25–20–15–10–505 005 008 PIN (dBm) 1768- PIN (dBm) 1768- 1 1 Figure 5. Log Conformance Error vs. PIN over Supply Voltage and Figure 8. Log Conformance Error vs. PIN over Supply Voltage and Temperature at 900 MHz Temperature at 1900 MHz Rev. B | Page 9 of 23 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MEASUREMENT SETUPS THEORY OF OPERATION APPLICATIONS INFORMATION BASIC CONNECTIONS TRANSFER FUNCTION IN TERMS OF SLOPE AND INTERCEPT LOG CONFORMANCE ERROR CALCULATION Filter Capacitor Input Coupling Options Effect of Waveform Type on Intercept Temperature Drift at High Frequencies Operation Above 4.5 GHz VLOG Output Noise VLOG Pulse Response Time Device Handling EVALUATION BOARD LAND PATTERN AND SOLDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
