Datasheet ADL5506 (Analog Devices) - 10
Description30 MHz to 4.5 GHz, 45 dB RF Detector
Pages / Page23 / 10 — ADL5506. Data Sheet. 1.2. –40°C. 1.1. 0°C. +25°C. +85°C. 1.0. 0.9. 0.8. E …
RevisionC
ADL5506. Data Sheet. 1.2. –40°C. 1.1. 0°C. +25°C. +85°C. 1.0. 0.9. 0.8. E (V). A 0.7. B) d. O 0.6. R (. IFT (. T V. U 0.5. RRO. 0.4. 0.3. 0.2. 0.1
ADL5506 Data Sheet 1.2 –40°C 1.1 0°C +25°C +85°C 1.0 0.9 0.8 E (V) A 0.7 B) d O 0.6 R ( IFT ( T V U 0.5 RRO 0.4 0.3 0.2 0.1
ADL5506 Data Sheet 1.2 6 1.2 6 –40°C –40°C 1.1 0°C 5 1.1 0°C +25°C 5 +25°C +85°C +85°C 1.0 4 1.0 4 0.9 3 0.9 3 0.8 2 0.8 E (V) E (V) 2 G G ) A 0.7 1 B) d A 0.7 LT 1 LT dB O 0.6 0 R ( O 0.6 IFT ( T V 0 T V R U 0.5 –1 RRO U 0.5 E D TP TP –1 0.4 –2 0.4 OU OU –2 0.3 –3 0.3 0.2 –4 0.2 –3 0.1 THREE-POINT CALIBRATION AT –5 0.1 –4 –35dBm, –25dBm, AND –5dBm CALIBRATION AT –30dBm AND –5dBm 0 –6 0 –5 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10
010
012
PIN (dBm)
1768-
P
1768- 1
IN (dBm)
1 Figure 9. VLOG and Log Conformance Error vs. PIN over Temperature at 30 MHz Figure 12. Distribution of Log Conformance Error with Respect to VLOG at 25°C vs. PIN and Temperature at 30 MHz
1.2 6 1.2 6 –40°C –40°C 0°C 1.1 0°C 5 1.1 5 +25°C +25°C +85°C +85°C 1.0 4 1.0 4 0.9 3 0.9 3 0.8 2 0.8 2 E (V) E (V) G G ) A 0.7 1 B) A 0.7 1 d dB LT LT O 0.6 0 R ( O 0.6 0 IFT ( T V T V R U 0.5 –1 RRO U 0.5 –1 D E TP TP 0.4 –2 0.4 –2 OU OU 0.3 –3 0.3 –3 0.2 –4 0.2 –4 0.1 THREE-POINT CALIBRATION AT –5 0.1 –5 –35dBm, –25dBm, and –5dBm CALIBRATION AT –30dBm AND –5dBm 0 –6 0 –6 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5
1 1
0 013
P P IN (dBm)
1768-
IN (dBm)
1768- 1 1 Figure 10. VLOG and Log Conformance Error vs. PIN over Temperature at 50 MHz Figure 13. Distribution of Log Conformance Error with Respect to VLOG at 25°C vs. PIN and Temperature at 50 MHz
1.2 6 1.2 6 –40°C TA = –40°C 1.1 0°C 5 1.1 T 5 +25°C A = 0°C +85°C TA = +25°C 1.0 4 1.0 T 4 A = +85°C 0.9 3 0.9 3 0.8 2 0.8 2 E (V) E (V) G G ) A 0.7 1 B) d A 0.7 1 dB LT LT O 0.6 0 R ( O 0.6 0 IFT ( T V T V R U 0.5 –1 RRO U 0.5 –1 E D TP TP 0.4 –2 0.4 –2 OU OU 0.3 –3 0.3 –3 0.2 –4 0.2 –4 0.1 THREE-POINT CALIBRATION AT –5 0.1 –5 –40dBm, –30dBm, and –10dBm CALIBRATION AT –30dBm AND –10dBm 0 –6 0 –6 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5
1
14 11 1
PIN (dBm)
1768-
P
1768- 1
IN (dBm)
1 Figure 11. VLOG and Log Conformance Error vs. PIN over Temperature at 100 MHz Figure 14. Distribution of Log Conformance Error with Respect to VLOG at 25°C vs. PIN and Temperature at 100 MHz Rev. B | Page 10 of 23 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MEASUREMENT SETUPS THEORY OF OPERATION APPLICATIONS INFORMATION BASIC CONNECTIONS TRANSFER FUNCTION IN TERMS OF SLOPE AND INTERCEPT LOG CONFORMANCE ERROR CALCULATION Filter Capacitor Input Coupling Options Effect of Waveform Type on Intercept Temperature Drift at High Frequencies Operation Above 4.5 GHz VLOG Output Noise VLOG Pulse Response Time Device Handling EVALUATION BOARD LAND PATTERN AND SOLDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
