Datasheet HMC662LP3E (Analog Devices) - 7
Description54 dB Logarithmic Detector, 8 - 30 GHz
Pages / Page8 / 7 — HMC662LP3E. 54 dB, LOGARITHMIC. DETECTOR, 8 - 30 GHz. Pin Descriptions …
File Format / SizePDF / 479 Kb
HMC662LP3E. 54 dB, LOGARITHMIC. DETECTOR, 8 - 30 GHz. Pin Descriptions (Continued). Application & Evaluation PCB Schematic
HMC662LP3E 54 dB, LOGARITHMIC DETECTOR, 8 - 30 GHz Pin Descriptions (Continued) Application & Evaluation PCB Schematic
HMC662LP3E
v05.0914
Pin Number Function Description Interface Schematic T M S Bias Supply. Connect supply voltage to - these pins with appropriate filtering. 14 - 16 Vcc1 To ensure proper start-up supply rise time RS should be faster than 100usec O T C TE E D R
WE O P Note1: C1 and C2 should be placed as close to the package as possible. Note2: Log out load should be 1K Ohm or higher. I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 • Fax: 978-250-3373 • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Ph e o r O ne n : 7 -l 81 i-n 3 e a 29-4t w 70 ww 0 • O .h rd iettit r o e nli.c n om
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p 3 p o lic ra a tiopp n S su@ p h po irtttit : Pe. hocnom e: 1-800-ANALOG-D
