Datasheet HMC602LP4, 602LP4E (Analog Devices) - 3
Description70 dB, LOGARITHMIC DETECTOR / CONTROLLER, 1 - 8000 MHz
Pages / Page8 / 3 — HMC602LP4 / 602LP4E. 70 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 1 - 8000 …
File Format / SizePDF / 540 Kb
HMC602LP4 / 602LP4E. 70 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 1 - 8000 MHz. LOGOUT Voltage & Error
HMC602LP4 / 602LP4E 70 dB, LOGARITHMIC DETECTOR / CONTROLLER, 1 - 8000 MHz LOGOUT Voltage & Error
HMC602LP4 / 602LP4E
v03.0209
70 dB, LOGARITHMIC DETECTOR / CONTROLLER, 1 - 8000 MHz LOGOUT Voltage & Error LOGOUT Voltage & Error vs. Input Power, Fin = 2200 MHz vs. Input Power, Fin = 3600 MHz
2.6 4 2.6 4 ERR +25C ERR +25C ERR +85C ERR +85C ERR -40C ERR -40C 2 2 2 2 ERROR (dB) ERROR (dB) 1.4 0 1.4 0 LOGOUT (V) LOGOUT (V) 0.8 Ideal -2 0.8 Ideal -2 LOGOUT +25C LOGOUT +25C LOGOUT +85C LOGOUT +85C 12 LOGOUT -40C LOGOUT -40C 0.2 -4 0.2 -4 -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) T
LOGOUT Voltage & Error LOGOUT Voltage & Error vs. Input Power, Fin = 5800 MHz vs. Input Power, Fin = 7000 MHz
2.6 4 2.6 6 S - SM Ideal ERR +25C R LOGOUT +25C ERR +85C LOGOUT +85C ERR -40C LOGOUT -40C 2 3 O 2 2 T ERROR (dB) ERROR (dB) C 1.4 0 1.4 0 E T LOGOUT (V) LOGOUT (V) E 0.8 -2 0.8 -3 Ideal ERR +25C LOGOUT +25C ERR +85C LOGOUT +85C ERR -40C LOGOUT -40C R D 0.2 -4 0.2 -6 E -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) W O
P
vs. Input Power, Fin = 8000 MHz LOGOUT vs. Frequency Over Input Power
2.4 10 2.4 -70dBm ERR +25C ERR +85C ERR -40C -50dBm 1.8 5 1.8 -60dBm -40dBm ERROR (dB) -30dBm 1.2 0 1.2 -20dBm OUT (V) LOGOUT (V) -10dBm 0.6 -5 0.6 0dBm Ideal LOGOUT +25C LOGOUT +85C 10dBm LOGOUT -40C 0 -10 0 0 1 2 3 4 5 6 7 8 -70 -60 -50 -40 -30 -20 -10 0 10 FREQUENCY (GHz) INPUT POWER (dBm) Unless otherwise noted: Vcc1, Vcc2, Vcc3 = +5V, TA = +25C Information furnis F heod r pri by An ce, de alog Devi lcievs eir s y b , a eliev nd to pla ed to be accu ce o rate anrder d relia sbl, pl e. H ease co owever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone: 978 rights of third parties that may result from its use. Specifications subject to change without notice. No Ph - o 25 ne 0 : 7 -3 81- 3 3 4 29 3 F -470 ax: 978 0 • Orde - r o 25 nlin 0- e a3 t 373
12 - 20
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Order On-l Trademarks and registered trademarks are the property of their respective owners. ine at www.hit A ti p te.co plicati m on Support: Phone: 1-800-ANALOG-D
