Datasheet HMC600LP4, 600LP4E (Analog Devices) - 5
Description75 dB LOGARITHMIC DETECTOR / CONTROLLER 50 - 4000 MHz
Pages / Page8 / 5 — HMC600LP4 / 600LP4E. 75 dB LOGARITHMIC. DETECTOR / CONTROLLER 50 - 4000 …
File Format / SizePDF / 510 Kb
HMC600LP4 / 600LP4E. 75 dB LOGARITHMIC. DETECTOR / CONTROLLER 50 - 4000 MHz. LOGOUT Voltage vs. Input Power and Frequency, T
HMC600LP4 / 600LP4E 75 dB LOGARITHMIC DETECTOR / CONTROLLER 50 - 4000 MHz LOGOUT Voltage vs Input Power and Frequency, T
HMC600LP4 / 600LP4E
v02.0909
75 dB LOGARITHMIC DETECTOR / CONTROLLER 50 - 4000 MHz LOGOUT Voltage vs. Input Power and Frequency, T Absolute Maximum Ratings A = +25C
2 Vcc1, Vcc2 0V to +5.5V PWD 0V to +5.5V 50 MHz 900 MHz VSET Input Voltage 0V to +5.5V 1900 MHz 3500 MHz LOGOUT Output Current 3 mA 1.5 4000 MHz RF Input Power +12 dBm Junction Temperature 125 °C LOGOUT (V) Continuous Pdiss (T = 85°C) 1 0.32 Watts (Derate 7.95 mW/°C above 85°C) Thermal Resistance (R ) th 126 °C/W 12 (junction to lead) Storage Temperature -65 to +150 °C 0.5 -75 -65 -55 -45 -35 -25 -15 -5 5 Operating Temperature -40 to +85 °C INPUT POWER (dBm) ESD Sensitivity (HBM) Class 1C T ELECTROSTATIC SENSITIVE DEVICE OBSERVE HANDLING PRECAUTIONS
Outline Drawing
S - SM R O T C E T E R D E W O P NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY 2. DIMENSIONS ARE IN INCHES [MILLIMETERS]. 3. LEAD SPACING TOLERANCE IS NON-CUMULATIVE 4. PAD BURR LENGTH SHALL BE 0.15mm MAXIMUM. PAD BURR HEIGHT SHALL BE 0.05mm MAXIMUM. 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND. 7. REFER TO HITTITE APPLICATION NOTE FOR SUGGESTED PCB LAND PATTERN. Unless otherwise noted: Vcc1, Vcc2 = +3.3V, TA = +25C Information furnis F heod r pri by An ce, de alog Devi lcievs eir s y b , a eliev nd to pla ed to be accu ce o rate anrder d relia sbl, pl e. H ease co owever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone: 978 rights of third parties that may result from its use. Specifications subject to change without notice. No Ph - o 25 ne 0 : 7 -3 81- 3 3 4 29 3 F -470 ax: 978 0 • Orde - r o 25 nlin 0- e a3 t 373
12 - 6
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Order On-l Trademarks and registered trademarks are the property of their respective owners. ine at www.hit A ti p te.co plicati m on Support: Phone: 1-800-ANALOG-D
