Datasheet AD8313 (Analog Devices) - 6
Description0.1 GHz to 2.5 GHz 70 dB Logarithmic Detector/Controller
Pages / Page24 / 6 — AD8313. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table. Parameter. Rating. …
RevisionE
File Format / SizePDF / 460 Kb
AD8313. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table. Parameter. Rating. ESD CAUTION
AD8313 Data Sheet ABSOLUTE MAXIMUM RATINGS Table Parameter Rating ESD CAUTION
3
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these Supply Voltage VS 5.5 V or any other conditions above those indicated in the operational VOUT, VSET, PWDN 0 V, VPOS section of this specification is not implied. Operation beyond Input Power Differential (re: 50 Ω, 5.5 V) 25 dBm the maximum operating conditions for extended periods may Input Power Single-Ended (re: 50 Ω, 5.5 V) 19 dBm affect product reliability. Internal Power Dissipation 200 mW θJA 200°C/W
ESD CAUTION
Maximum Junction Temperature 125°C Operating Temperature Range –40°C to +85°C Storage Temperature Range –65°C to +150°C Rev. E | Page 6 of 24 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Description Typical Performance Characteristics Circuit Description Interfaces Power-Down Interface, PWDN Signal Inputs, INHI, INLO Logarithmic/Error Output, VOUT Setpoint Interface, VSET Applications Information Basic Connections for Log (RSSI) Mode Operating in Controller Mode Input Coupling Narrow-Band LC Matching Example at 100 MHz Adjusting the Log Slope Increasing Output Current Effect of Waveform Type on Intercept Evaluation Board Schematic and Layout General Operation Using the AD8009 Operational Amplifier Varying the Logarithmic Slope Operating in Controller Mode RF Burst Response Outline Dimensions Ordering Guide
