Datasheet AD8210 (Analog Devices) - 8
Description | High Voltage, Bidirectional Current Shunt Monitor |
Pages / Page | 15 / 8 — ) A. INPUT (50V/DIV). (m T EN. R R U. OUTPUT (200mV/DIV). K N SI. T PU T. … |
Revision | F |
File Format / Size | PDF / 1.9 Mb |
) A. INPUT (50V/DIV). (m T EN. R R U. OUTPUT (200mV/DIV). K N SI. T PU T. U O M. MU XI. 200ns/DIV. –40. –20. 100. 120. 140. TEMPERATURE (°C). 700
8 ) A 7 INPUT (50V/DIV) (m T EN 6 R R U 5 C OUTPUT (200mV/DIV) K N SI 4 T PU T 3 U O M 2 MU XI 1 MA
0 2 -0 7 4
0 200ns/DIV
1 2 5 2 0
–40 –20 0 20 40 60 80 100 120 140
-0 7 4
TEMPERATURE (°C)
1 5 0
700 11 V) ) A 10 (m R 600 (m T O 9 EN RR R E 8 500 R Y U C ER 7 E V C 400 R CO 6 U E R SO 5 P 300 T TE PU S 4 T E U 200 O 3 OD M -M MU 2 ON 100 XI M 1 MA OM C 0
7
0
1
–4
6
2
60 150 240 330 420 510 600 690
-1 7 -0 4 7 1 4
RISE TIME (ns)
5
TEMPERATURE (°C)
1 0 5 0
800 ) 5.0 V 4.9 (m 700 R 4.8 O 4.7 RR (V) E 600 E 4.6 Y G R E N 4.5 V 500 A R O 4.4 C E E G 4.3 R 400 A P T L 4.2 E T 4.1 S 300 VO E T 4.0 D PU O T 200 3.9 -M U N O 3.8 O 100 3.7 MM O 3.6 C 0 3.5
8 3 2
1
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5
-1 -0 7 7 4 4 1
FALL TIME (ns)
1 5
OUTPUT SOURCE CURRENT (mA)
5 0 0 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MODES OF OPERATION UNIDIRECTIONAL OPERATION Ground Referenced Output V+ Referenced Output BIDIRECTIONAL OPERATION External Referenced Output Splitting an External Reference Splitting the Supply INPUT FILTERING APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSE WITH A HIGH-SIDE SWITCH H-BRIDGE MOTOR CONTROL OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
