Very High Common-Mode Voltage Precision Difference Amplifier
Pages / Page
17 /8 — AD8479. Data Sheet. 150. VS = +5V, VREF = MIDSUPPLY. 100. –10. E (V) G. …
Revision
C
PDF / 396 Kb
AD8479. Data Sheet. 150. VS = +5V, VREF = MIDSUPPLY. 100. –10. E (V) G. –20. A LT. B) d –30. E VO. N (. AI –40. -MO. –50. MMO O. –60. –70. –80. –100. 10k. 100k
AD8479Data Sheet10150VS = +5V, VREF = MIDSUPPLY0100–10E (V) G–20A LT50B) d –30E VON (DAI –40G-MO0N–50MMO O–60C–50–70–80–1001001k10k100k1M10M 12 009 00.51.01.52.02.53.03.54.04.55.0 1 18- FREQUENCY (Hz)V 11118- OUT (V) 111 Figure 12. Small Signal Frequency Response Figure 15. Input Common-Mode Voltage vs. Output Voltage, Single Supply, VS = +5 V, VREF = Midsupply 800VS = ±15V6004005V/DIVVOUTE (V) GVS = ±5VA200LTE VO5.9µs TO 0.01%0D8.7µs TO 0.001%-MO N –2000.002%/DIVVOUT SETTLINGMMO –400O C–600 113 –800–20TIME (10µs/DIV)–15–10–505101520 210 11118- 18- VOUT (V) 111 Figure 13. Input Common-Mode Voltage vs. Output Voltage, Dual Supplies, Figure 16. Settling Time VS = ±15 V, ±5 V 25020VS = +5V, VREF = 0VRL = 2kΩ20015CL = 1000pFE (V)10G A150LT5E VO100D(V)UT0O-MOVN50–5MMO O C–100–15–50 1 114 00.51.01.52.02.53.03.54.04.55.0 11 –20 18- TIME (4µs/DIV)V 11118- OUT (V) 111 Figure 14. Input Common-Mode Voltage vs. Output Voltage, Single Supply, Figure 17. Large Signal Pulse Response VS = +5 V, VREF = 0 V Rev. C | Page 8 of 17 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION BASIC CONNECTIONS SINGLE-SUPPLY OPERATION SYSTEM-LEVEL DECOUPLING AND GROUNDING USING A LARGE SHUNT RESISTOR OUTPUT FILTERING GAIN OF 60 DIFFERENTIAL AMPLIFIER ERROR BUDGET ANALYSIS EXAMPLE OUTLINE DIMENSIONS ORDERING GUIDE
