16 /7 — Data Sheet. AD8275. 120. 100. ) B. E (V) G. IO T EC. E VO. -MO. Y R. PPL. …
Revision
B
PDF / 541 Kb
Data Sheet. AD8275. 120. 100. ) B. E (V) G. IO T EC. E VO. -MO. Y R. PPL. MMO. –10. –15. –20. –25. –0.5. 0.5. 1.0. 1.5. 2.0. 2.5. 3.0. 3.5. 4.0. 4.5. 5.0. 5.5. 10k. 100k
Data SheetAD8275351203010025) BE (V) G20(dANT80L15IO T ECE VO1060DEJ5-MOY RN040PPLMMO–5SUO20C–10ERTWPU–15POIN0 010 –20 013 –25 07546- 07546- –20–0.500.51.01.52.02.53.03.54.04.55.05.51001k10k100k1MOUTPUT VOLTAGE (V)FREQUENCY (Hz) Figure 11. Input Common-Mode Voltage vs. Output Voltage, No Load Figure 14. Power Supply Rejection vs. Frequency, Referred to Output 06–5) -p5–10E (V p G4A–15T LB) dVO–20N (T3AIPUGT–25U2M O–30MU XI1–35MA 011 014 –40 07546- 07546- 01001k10k100k1M10M100M1001k10k100k1M10MFREQUENCY (Hz)FREQUENCY (Hz) Figure 12. Gain vs. Frequency Figure 15. Maximum Output Voltage vs. Frequency 100201590B) d) 10N ( IOppm80(CT5ITYJER ARE70E0DELINO M–5ONN-60NOINM M–10GACO50–15 012 015 07546- 40 07546- –201001k10k100k1M10M01234FREQUENCY (Hz)OUTPUT VOLTAGE (V) Figure 13. Common-Mode Rejection vs. Frequency, Referred to Input Figure 16. Gain Nonlinearity, RL = 600 Ω, 2 kΩ, 10 kΩ Rev. B | Page 7 of 16 Document Outline Features Applications Pin Configuration Typical Application General Description Revision History Specifications Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Basic Connection Power Supplies Reference Common-Mode Input Voltage Range Input Protection Configurations Applications Information Driving a Single-Ended ADC Differential Outputs Increasing Input Impedance AC Coupling Using the AD8275 as a Level Translator in a Data Acquisition System Outline Dimensions Ordering Guide
