Datasheet LTC7132 (Analog Devices) - 117
Description25A, Dual PolyPhase Regulator with Digital Power System Management
Pages / Page118 / 117 — PACKAGE DESCRIPTION. 2.22mm). NOTES. 9.00mm. MAX. BGA Package. …
File Format / SizePDF / 4.3 Mb
PACKAGE DESCRIPTION. 2.22mm). NOTES. 9.00mm. MAX. BGA Package. DIMENSIONS. NOM. MIN. 140-Lead (11.25mm. SYMBOL
PACKAGE DESCRIPTION 2.22mm) NOTES 9.00mm MAX BGA Package DIMENSIONS NOM MIN 140-Lead (11.25mm SYMBOL
LTC7132
PACKAGE DESCRIPTION
7 AIL A 0117 REV Ø SEE NOTES DET PIN 1 BGA 140 A B C D E F G H J K L M N P Y 1 AR ACKAGE TED. Y V 2 ATION 3 4 TIONAL, 5 TOM VIEW G 6 Y LOADING ORIENT Y BE EITHER A MOLD OR b 7 TING PLANE Y 8 PACKAGE BOT TED WITHIN THE ZONE INDICA 9 TION PER JEP95 LTMXXXX µModule e TURE PACKAGE IN TRA 10 TUM -Z- IS SEA YOUT CAREFULL Y DA PACKAGE ROW AND COLUMN LABELING MA AMONG µModule PRODUCTS. REVIEW EACH P LA AILS OF PIN #1 IDENTIFIER ARE OP
b e LL DIMENSIONS ARE IN MILLIMETERS DET BUT MUST BE LOCA THE PIN #1 IDENTIFIER MA MARKED FEA F 3 OR Sn Pb EUTECTIC NOTES: 1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M-1994 2. A 3 BALL DESIGNA 4 5. PRIMAR 6. SOLDER BALL COMPOSITION CAN BE 96.5% Sn/3.0% Ag/0.5% Cu 7 SEE NOTES Y PIN 1 BEVEL PIN “A1” TRA COMPONENT Z ×
2.22mm)
TE THK A A2 AIL B DET
NOTES
BALL HT BALL DIMENSION PAD DIMENSION SUBSTRA MOLD CAP HT 140 PACKAGE SIDE VIEW ×
9.00mm MAX
2.42 0.50 1.92 0.55 0.43 0.37 1.55 0.15 0.10 0.20 0.15 0.08 Z TE Y X
BGA Package
H1 Z Z TC DWG # 05-08-1569 Rev Ø) A1 SUBSTRA M M
DIMENSIONS NOM
2.22 0.40 1.82 0.50 0.40 11.25 9.0 0.80 10.40 7.2 0.32 1.50 ddd eee AL NUMBER OF BALLS: b1 AIL B AIL A H2
MIN
2.02 0.30 1.72 0.45 0.37 0.27 1.45 TOT ccc Z DET MOLD CAP DET (Reference L // bbb Z
140-Lead (11.25mm
Øb (140 PLACES) A A1 A2 b b1 D E e F G H1 H2 aaa bbb ccc ddd eee
SYMBOL
aaa Z 0.000 D X Y 5.200 4.400 3.600 2.800 2.000 1.200 0.400 0.400 1.200 2.000 2.800 3.600 4.400 5.200 3.600 2.800 2.000 1.200 YOUT 0.400 E 0.000 0.400 TOP VIEW 1.200 PACKAGE TOP VIEW 2.000 SUGGESTED PCB LA 2.800 4 PIN “A1” CORNER 3.600 aaa Z 0.4 Ø 140x Rev 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications For more information www.a subject to change without notice. No license is granted by implication or other nalog.com wise under any patent or patent rights of Analog Devices. 117 Document Outline Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Overview Main Control Loop EEPROM Power-Up and Initialization Soft-Start Time-Based Sequencing Voltage-Based Sequencing Shutdown Light-Load Current Operation Switching Frequency and Phase PWM Loop Compensation Output Voltage Sensing INTVCC/EXTVCC Power Output Current Sensing and Sub-Milliohm DCR Current Sensing Input Current Sensing PolyPhase Load Sharing External/Internal Temperature Sense RCONFIG (Resistor Configuration) Pins Fault Detection and Handling Status Registers and ALERT Masking Mapping Faults to FAULT Pins Power Good Pins CRC Protection Serial Interface Communication Protection Device Addressing Responses to VOUT and IIN/IOUT Faults Output Overvoltage Fault Response Output Undervoltage Response Peak Output Overcurrent Fault Response Responses to Timing Faults Responses to VIN OV Faults Responses to OT/UT Faults Internal Overtemperature Fault Response External Overtemperature and Undertemperature Fault Response Responses to Input Overcurrent and Output Undercurrent Faults Responses to External Faults Fault Logging Bus Timeout Protection Similarity Between PMBus, SMBus and I2C 2-Wire Interface PMBus Serial Digital Interface PMBus Command Summary PMBus Commands *Data Format Applications Information Current Limit Programming ISENSE0± and ISENSE1± Pins Inductor DCR Sensing Inductor Value Calculation Inductor Core Selection Low Value Resistor Current Sensing Slope Compensation and Inductor Peak Current Variable Delay Time, Soft-Start and Output Voltage Ramping Digital Servo Mode Soft Off (Sequenced Off) INTVCC/EXTVCC Power Topside MOSFET Driver Supply (CB, DB) Undervoltage Lockout CIN and COUT Selection Fault INDICATION Open-Drain Pins Phase-Locked Loop and Frequency Synchronization Minimum On-Time Considerations External Temperature Sense Input Current Sense Amplifier External Resistor Configuration Pins (RCONFIG) Voltage Selection Frequency Selection Phase Selection Address Selection Using RCONFIG Efficiency Considerations Thermal Considerations Programmable Loop Compensation Checking Transient Response PolyPhase Configuration PC Board Layout Checklist PC Board Layout Debugging Design Example Additional Design Checks Connecting the USB to I2C/SMBus/PMBus Controller to the LTC7132 in System LTpowerPlay: An Interactive GUI for Digital Power PMBus Communication and Command Processing PMBus Command Details Addressing and Write Protect General Configuration Commands On/Off/Margin PWM Configuration Voltage Input Voltage and Limits Output Voltage and Limits Output Current and Limits Input Current and Limits Temperature External Temperature Calibration Timing Timing—On Sequence/Ramp Timing—Off Sequence/Ramp Precondition for Restart Fault Response Fault Responses All Faults Fault Responses Input Voltage Fault Responses Output Voltage Fault Responses Output Current Fault Responses IC Temperature Fault Responses External Temperature Fault Sharing Fault Sharing Propagation Fault Sharing Response Scratchpad Identification Fault Warning and Status Telemetry NVM Memory Commands Store/Restore Fault Logging Block Memory Write/Read Typical Applications Package Description Typical Application Related Parts
