Datasheet TCR5RG (Toshiba)
ManufacturerToshiba
DescriptionUltra high Ripple rejection ratio, 500 mA CMOS Low Dropout Regulator in ultra small package
Pages / Page10 / 1 — TCR5RG series. 1. Description. 2. Applications. 3. Features
File Format / SizePDF / 483 Kb
Datasheet TCR5RG Toshiba
TCR5RG series
TOSHIBA CMOS Linear Integrated Circuit Silicon Monolithic
TCR5RG series
1. Description
The TCR5RG series are CMOS general-purpose single-output voltage regulators with an on/off control input, featuring low dropout voltage and ultra high Ripple rejection ratio. These voltage regulators are available in fixed output voltages between 0.9 V and 5.0 V and capable of driving up to 500 mA. They feature Overcurrent protection, Thermal shutdown and Auto-discharge. The TCR5RG series is of ered in the ultra small plastic mold WCSP4F package WCSP4F (0.645 mm x 0.645 mm (typ.); t 0.33 mm (max)) and has a high ripple rejection ratio of 100 dB (f = 1 kHz, 2.8 V output). As smal ceramic input and output capacitors 1μF can be used with the TCR5RG series, these devices are ideal for portable applications that require high-density board assembly such as cel ular phones.
2. Applications
Power IC developed for portable applications
3. Features
• Ultra smal package WCSP4F (0.645 mm x 0.645 mm (typ.); t 0.33 mm (max)). • High Ripple rejection ratio 100 dB (Typ.) @1 kHz at 2.8 V-output • High Ripple rejection ratio 93 dB (Typ.) @10 kHz at 2.8 V-output • High Ripple rejection ratio 67 dB (Typ.) @100 kHz at 2.8 V-output • High Ripple rejection ratio 59 dB (Typ.) @1 MHz at 2.8 V-output • Low output noise voltage ( VNO = 5 μVrms (Typ.) at 10Hz ≤ f ≤ 100kHz) • Low quiescent current ( IB = 7 μA (Typ.) at IOUT = 0 mA) • Overcurrent protection • Thermal shutdown • Auto-discharge • Low Dropout voltage VDO = 150 mV (Typ.) at 2.8 V-output, IOUT = 500 mA • Wide range output voltage line up ( VOUT = 0.9 to 5.0 V ) • Pul down connection between CONTROL and GND • Ceramic capacitors can be used (CIN = 1 μF, COUT =1 μF) Start of commercial production 2020-12 © 2020 1 2020-12-18 Toshiba Electronic Devices & Storage Corporation
