Datasheet TCR5RG (Toshiba) - 2
ManufacturerToshiba
DescriptionUltra high Ripple rejection ratio, 500 mA CMOS Low Dropout Regulator in ultra small package
Pages / Page10 / 2 — TCR5RG series. 4. Absolute Maximum Ratings (Ta = 25°C). 5. Pin Assignment …
File Format / SizePDF / 483 Kb
TCR5RG series. 4. Absolute Maximum Ratings (Ta = 25°C). 5. Pin Assignment (top view). 6. Operating Ranges
TCR5RG series 4 Absolute Maximum Ratings (Ta = 25°C) 5 Pin Assignment (top view) 6 Operating Ranges
TCR5RG series 4. Absolute Maximum Ratings (Ta = 25°C)
Characteristics Symbol Rating Unit Input voltage VIN -0.3 to 6.0 V Control voltage VCT -0.3 to VIN + 0.3 ≤ 6.0 V Output voltage VOUT -0.3 to VIN + 0.3 ≤ 6.0 V Output current IOUT 500 mA Power dissipation PD 800 (Note1) mW Junction temperature Tj 150 °C Storage temperature range Tstg −55 to 150 °C Note: Using continuously under heavy loads (e.g. the application of high temperature/current/voltage and the significant change in temperature, etc.) may cause this product to decrease in the reliability significantly even if the operating conditions (i.e. operating temperature/current/voltage, etc.) are within the absolute maximum ratings and the operating ranges. Please design the appropriate reliability upon reviewing the Toshiba Semiconductor Reliability Handbook (“Handling Precautions”/“Derating Concept and Methods”) and individual reliability data (i.e. reliability test report and estimated failure rate, etc). Note1: Rating at mounting on a board Glass epoxy(FR4) board dimension: 40mm x 40mm x 1.6mm, both sides of board. Metal pattern ratio: a surface approximately 50%, the reverse side approximately 50% Through hole hall: diameter 0.5 mm x 24
5. Pin Assignment (top view) 1 2 1 2 A A
VIN VOUT
B B
CONTROL GND
6. Operating Ranges
Characteristics Symbol Rating Unit Input voltage VIN 1.8 to 5.5 (Note 2) V Control voltage VCT 0 to VIN V Output voltage V OUT 0.9 to 5.0 V Output current IOUT DC 500 mA Operation Temperature Topr -40 to 85 °C Output Capacitance COUT ≥ 1.0 μF ― Input Capacitance CIN ≥ 1.0 μF ― Note 2: Please refer to Dropout Voltage table (Page 6) and use it within Absolute Maximum Ratings Junction temperature and Operation Temperature Ranges. © 2020 2020-12-18 Toshiba Electronic Devices & Storage Corporation
