Datasheet C2M1000170D (Wolfspeed) - 2
ManufacturerWolfspeed
DescriptionSilicon Carbide Power MOSFET 1700 V 5.0 A 1.0 Ω
Pages / Page10 / 2 — Electrical Characteristics. Symbol. Parameter. Min. Typ. Max. Unit. Test …
File Format / SizePDF / 996 Kb
Electrical Characteristics. Symbol. Parameter. Min. Typ. Max. Unit. Test Conditions. Note. Reverse Diode Characteristics
Electrical Characteristics Symbol Parameter Min Typ Max Unit Test Conditions Note Reverse Diode Characteristics
(T = 25˚C unless otherwise specified) C
Symbol Parameter Min. Typ. Max. Unit Test Conditions Note
V(BR)DSS Drain-Source Breakdown Voltage 1700 V VGS = 0 V, ID = 100 μA 2.0 2.8 4 V VDS = VGS, ID = 0.5 mA V Fig. 11 GS(th) Gate Threshold Voltage 2.4 V VDS = VGS, ID = 0.5 mA, TJ = 150 °C IDSS Zero Gate Voltage Drain Current 1 100 μA VDS = 1.7 kV, VGS = 0 V IGSS Gate-Source Leakage Current 250 nA VGS = 20 V, VDS = 0 V 0.80 1.4 VGS = 20 V, ID = 2 A RDS(on) Drain-Source On-State Resistance Ω Fig. 4,5,6 1.4 VGS = 20 V, ID = 2 A, TJ = 150 °C 1.04 VDS= 20 V, IDS= 2 A g Fig. 7 fs Transconductance S 1.09 VDS= 20 V, IDS= 2 A, TJ = 150 °C Ciss Input Capacitance 215 VGS = 0 V Coss Output Capacitance 19 pF V Fig. 17,18 DS = 1000 V Crss Reverse Transfer Capacitance 2.2 f = 1 MHz VAC = 25 mV Eoss Coss Stored Energy 10.2 μJ Fig 16 EON Turn-On Switching Energy 89 VDS = 1.2 kV, VGS = -5/20 V μJ I = 2 A, R = 2.5 Ω, Fig. 26 D G(ext) EOFF Turn Off Switching Energy 14 L= 1478 μH, TJ = 150 °C td(on) Turn-On Delay Time 5 VDD = 1.2 kV, VGS = -5/20 V tr Rise Time 19 I = 600 Ω ns D = 2 A, RG(ext) = 2.5 Ω, RL Fig. 27 Timing relative to V t DS d(off) Turn-Off Delay Time 14 Per IEC60747-8-4 pg 83 tf Fall Time 63 RG(int) Internal Gate Resistance 24.8 Ω f = 1 MHz, VAC = 25 mV Qgs Gate to Source Charge 4 VDS = 1.2 kV, VGS = -5/20 V Qgd Gate to Drain Charge 12 nC ID = 2 A Fig. 12 Per IEC60747-8-4 pg 21 Qg Total Gate Charge 22
Reverse Diode Characteristics Symbol Parameter Typ. Max. Unit Test Conditions Note
3.8 V V = - 5 V, I = 1 A, T = 25 °C V GS SD J Fig. 8, 9, SD Diode Forward Voltage 10 3.3 V V = - 5 V, I = 1 A, T = 150 °C GS SD J IS Continuous Diode Forward Current 4 A T = 25 °C Note 1 C t Reverse Recovery Time 30 ns V = - 5 V, I = 2 A T = 150 °C rr GS SD J V = 1.2 kV R Q Reverse Recovery Charge 31 nC Note 1 rr dif/dt = 1135 A/µs I Peak Reverse Recovery Current 3 A rrm Note (1): When using SiC Body Diode the maximum recommended V = -5V GS
Thermal Characteristics Symbol Parameter Typ. Max. Unit Test Conditions Note
RθJC Thermal Resistance from Junction to Case 1.7 1.8 °C/W Fig. 21 RθJA Thermal Resistance from Junction to Ambient 40
2
C2M1000170D Rev. 7, 02-2021
