Datasheet MM5130 (Menlo Micro)
Manufacturer | Menlo Micro |
Description | DC to 26 GHz High Power RF Switch |
Pages / Page | 22 / 1 — Datasheet. MM5130 – DC to 26 GHz High Power RF Switch Product Overview. … |
File Format / Size | PDF / 1.3 Mb |
Datasheet. MM5130 – DC to 26 GHz High Power RF Switch Product Overview. Description. Features:. Applications:. Markets:
Datasheet MM5130 – DC to 26 GHz High Power RF Switch Product Overview Description
The MM5130 device is a high-power SP4T micro-mechanical switch offered by Menlo Micro. Menlo Micro has developed a new Ideal SwitchTM fabrication process and applied it to DC and wideband RF/microwave switch applications. This innovative technology enables highly reliable switches capable of 25 W forward power. The MM5130 provides ultra-low insertion loss and superior linearity as an SP4T from DC to 18 GHz, and greater than 3 billion switching cycles. The MM5130 can also be configured in super-port mode that extends the frequency operation to 26 GHz. The MM5130 is an ideal solution for replacing large RF electromechanical relays, as well as RF/microwave solid-state switches in applications where linearity and insertion loss are critical parameters. The four switch channels are individually controllable by applying a gate voltage to the corresponding RF GATE pin.
Features:
● DC to 26 GHz Frequency Range ● 25 W (CW), 150 W (Pulsed) Max Power Handling ● Low On-State Insertion Loss: 0.4 dB @ 6.0 GHz ● High Linearity, IIP3 95 dBm Typical ● 25 dB Isolation @ 6.0 GHz / 45 dB Super-Port Mode ● High Reliability > 3.0x109 Switching Operations ● 2.5 mm x 2.5 mm WLCSP Package MM5130
Applications:
RF1 RF1GATE
Switched Filter Banks and Tunable Filters RF2 ● High RFC RF2GATE Power RF Front Ends RF3 ● Antenna Tuning RF3GATE RF4 ● Low-Loss Switch Matrices & EM Relay Replacement RF4GATE
Markets:
Functional Block Diagram
Defense and Aerospace ● Medical Equipment ● Test and Measurement Systems ● Wireless Infrastructure © 2020 Menlo Microsystems, Inc. | All Rights Reserved | www.menlomicro.com
