Datasheet MM5600 (Menlo Micro)
Manufacturer | Menlo Micro |
Description | 40Gbps DPDT Differential Switchwith Integrated Driver |
Pages / Page | 17 / 1 — Preliminary Datasheet. MM5600 - 40 Gbps DPDT Differential Switch with … |
File Format / Size | PDF / 753 Kb |
Preliminary Datasheet. MM5600 - 40 Gbps DPDT Differential Switch with Integrated Driver. Product Overview. Description
Preliminary Datasheet MM5600 - 40 Gbps DPDT Differential Switch with Integrated Driver Product Overview Description
Menlo Micro has developed a DPDT switch for high-speed differential signal switching. The MM5600 is based on Menlo’s Ideal SwitchTM technology and can operate for digital signals up to 40 Gbps or RF signals up to 20 GHz for high-performance applications. The MM5600 has low insertion loss, fast switching speed, internal ESD diodes, and can operate with greater than three billion switching cycles. The MM5600’s integrated driver is controlled by a serial-to-parallel interface that drives the high voltage gate lines of the switches. The design also offers two separate single-ended ports and a considerable 90% reduction in size when compared with comparable EM relay solutions. An external +5 VDC logic supply and high voltage +89 VDC bias source is required for operation of the internal switch driver.
Features
● DC to 20 GHz range, up to 40 Gbps ● Low Insertion Loss ● Integrated driver eliminates requirement for an external gate driver ● Independently controlled dual loopback ports ● High Reliability: Greater than 3 billion switching
MM5600
operations
LB2/AUX2 Applications OUT1A OUT1B ●
Differential High-Speed Switching
RFINA RFINB
OUT2A
ATE-Device Interface Boards
OUT2B
● High-Speed Computer Peripheral Interfaces
LB1/AUX1 Markets t1 t2 t3 t8 u u u u o o o o V V V V H H H H ●
Differential Component Testing
High Voltage Gate Driver
● Differential Signal Routing ●
D D D B T
Test and Measurement
N D B I LK LE BL D N V N D C N V G G OU V G V D R H D
© 2021 Menlo Microsystems, Inc. | All Rights Reserved | www.menlomicro.com
