Datasheet MM5600 (Menlo Micro) - 5
Manufacturer | Menlo Micro |
Description | 40Gbps DPDT Differential Switchwith Integrated Driver |
Pages / Page | 17 / 5 — PRELIMINARY DATASHEET v1.1. High-Voltage Bias Supply Voltage (VBB)13. … |
File Format / Size | PDF / 753 Kb |
PRELIMINARY DATASHEET v1.1. High-Voltage Bias Supply Voltage (VBB)13. High-Voltage Bias Supply Current (IBB)14
5 MM5600 - 40 Gbps DPDT Differential Switch
PRELIMINARY DATASHEET v1.1 High-Voltage Bias Supply Voltage (VBB)13
88 89 90 VDC
TBD uA 13 Note that High-Voltage Bias must be applied to VBB. It is not part of the integrated driver. 14 Measured at VBB = 100V and no load. © 2021 Menlo Microsystems, Inc. | All Rights Reserved | www.menlomicro.com
