Datasheet AOZ7200CI (Alpha & Omega)
ManufacturerAlpha & Omega
Description600V - AlphaZBL
Pages / Page9 / 1 — ALPHA & OMEGA. AOZ7200CI. 600V - AlphaZBLTM. General Description. …
File Format / SizePDF / 623 Kb
ALPHA & OMEGA. AOZ7200CI. 600V - AlphaZBLTM. General Description. Features. Applications. Typical Applications. AOZ7200
Datasheet AOZ7200CI Alpha & Omega
ALPHA & OMEGA AOZ7200CI
S E M I C O N D U C T O R
600V - AlphaZBLTM General Description Features
The AOZ7200CI is a 600V AlphaZBL product that control • Replaces a power diode in HV bridge rectifier the external N-channel MOSFET to replace a diode when • Self-powered in AC system used in AC/DC diode-bridge application. The AOZ7200CI • Low reverse threshold 1mV can help to reduce power consumption, heat dissipation. • Low quiescent current 5uA In diode-bridge application, the AOZ7200CI senses the
Applications
voltage drop and reduces the forward conduction loss to the minimum value. When the forward current is reversed, the • AC/DC AOZ7200CI will turn-off the external switch and suffers the • HV bridge rectifier application reverse voltage. In AC/DC application, the AOZ7200CI is self-powered system without extra voltage supply. The AOZ7200CI is available in a SOT23-5 package and is rated over a -40°C to +125°C ambient temperature range.
AOZ7200
AOZ7200
Vin Downstream Load * * *
AOZ7200
AOZ7200
* Option
Figure 1. Application Circuit
Rev. 1.0 October 2020
www.aosmd.com
Page 1 of 9
