Datasheet 74HC4060, 74HCT4060 (NXP) - 3
Manufacturer | NXP |
Description | 14-stage binary ripple counter with oscillator |
Pages / Page | 20 / 3 — Nexperia. 74HC4060; 74HCT4060. 14-stage binary ripple counter with … |
File Format / Size | PDF / 324 Kb |
Nexperia. 74HC4060; 74HCT4060. 14-stage binary ripple counter with oscillator. Fig. 4. Logic diagram. 6. Pinning information
Nexperia 74HC4060; 74HCT4060 14-stage binary ripple counter with oscillator
CTC FF FF FF FF FF RTC 1 4 10 12 14 RS CP CP CP CP CP Q Q Q Q Q MR MR MR MR MR MR Q3 Q9 Q11 Q13 001aai114
Fig. 4. Logic diagram 6. Pinning information 6.1. Pinning 74HC4060 74HCT4060
terminal 1 11 C
74HC4060
Q V C index area
74HCT4060
1 16 Q12 2 15 Q9 Q11 1 16 VCC Q13 3 14 Q7 Q12 2 15 Q9 Q5 4 13 Q8 Q13 3 14 Q7 Q4 5 12 MR Q6 6 11 RS V Q5 4 13 Q8 CC(1) Q3 7 10 RTC Q4 5 12 MR 8 9 D Q6 6 11 RS N TC 001aai469 G C Q3 7 10 RTC Transparent top view (1) This is not a supply pin. There is no electrical or GND 8 9 CTC mechanical requirement to solder the pad. In case 001aai115 soldered, the solder land should remain floating or
Fig. 5. Pin configuration SOT109-1 (SO16), SOT338-1
connected to VCC
(SSOP16) and SOT403-1 (TSSOP16) Fig. 6. Pin configuration SOT763-1 (DHVQFN16) 6.2. Pin description Table 2. Pin description Symbol Pin Description
Q11, Q12, Q13 1, 2, 3 counter output Q3, Q4, Q5, Q6, Q7, Q8, Q9 7, 5, 4, 6, 14, 13, 15 counter output GND 8 ground (0 V) CTC 9 external capacitor connection RTC 10 external resistor connection RS 11 clock input /oscillator pin MR 12 master reset input (active HIGH) VCC 16 supply voltage 74HC_HCT4060 All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2020. Al rights reserved
Product data sheet Rev. 5 — 8 May 2020 3 / 20
Document Outline 1. General description 2. Features and benefits 3. Applications 4. Ordering information 5. Functional diagram 6. Pinning information 6.1. Pinning 6.2. Pin description 7. Functional description 8. Limiting values 9. Recommended operating conditions 10. Static characteristics 11. Dynamic characteristics 11.1. Waveforms and test circuit 12. RC oscillator 12.1. Timing component limitations 12.2. Typical crystal oscillator circuit 13. Package outline 14. Abbreviations 15. Revision history 16. Legal information Contents
