Datasheet MAX4014, MAX4017, MAX4019, MAX4022 (Maxim) - 7
Manufacturer | Maxim |
Description | Low-Cost, High-Speed, Single-Supply, Gain of +2 Buffers with Rail-to-Rail Outputs in SOT23 |
Pages / Page | 12 / 7 — Low-Cost, High-Speed, Single-Supply, Gain of +2. Buffers with … |
File Format / Size | PDF / 283 Kb |
Low-Cost, High-Speed, Single-Supply, Gain of +2. Buffers with Rail-to-Rail Outputs in SOT23
Low-Cost, High-Speed, Single-Supply, Gain of +2 Buffers with Rail-to-Rail Outputs in SOT23 MAX4014/MAX4017/MAX4019/MAX4022 ______________________________________________________________Pin Description PIN MAX4014 MAX4017 MAX4019 MAX4022 NAME FUNCTION SOT23-5 SO/µMAX SO QSOP SO QSOP
No Connect. Not internally connected. Tie to — — — 8, 9 — 8, 9 N.C. ground or leave open. 1 — — — — — OUT Amplifier Output Negative Power Supply or Ground 2 4 11 13 11 13 VEE (in single-supply operation) 3 — — — — — IN+ Noninverting Input 4 — — — — — IN- Inverting Input 5 8 4 4 4 4 VCC Positive Power Supply — 1 7 7 1 1 OUTA Amplifier A Output — 2 6 6 2 2 INA- Amplifier A Inverting Input — 3 5 5 3 3 INA+ Amplifier A Noninverting Input — 7 8 10 7 7 OUTB Amplifier B Output — 6 9 11 6 6 INB- Amplifier B Inverting Input — 5 10 12 5 5 INB+ Amplifier B Noninverting Input — — 14 16 8 10 OUTC Amplifier C Output — — 13 15 9 11 INC- Amplifier C Inverting Input — — 12 14 10 12 INC+ Amplifier C Noninverting Input — — — — 14 16 OUTD Amplifier D Output — — — — 13 15 IND- Amplifier D Inverting Input — — — — 12 14 IND+ Amplifier D Noninverting Input — — 1 1 — — ENA Enable Input for Amplifier A — — 3 3 — — ENB Enable Input for Amplifier B — — 2 2 — — ENC Enable Input for Amplifier C
_______________________________________________________________________________________ 7
