Datasheet AIS2IH (STMicroelectronics) - 8
DescriptionMEMS digital output motion sensor: high-performance 3-axis accelerometer for automobile applications
Pages / Page63 / 8 — AIS2IH. Temperature sensor characteristics. 2.3. Table 5. Temperature …
AIS2IH. Temperature sensor characteristics. 2.3. Table 5. Temperature sensor characteristics. Symbol. Parameter. Min. Typ. (1). Max. Unit
AIS2IH Temperature sensor characteristics 2.3 Table 5 Temperature sensor characteristics Symbol Parameter Min Typ (1) Max Unit
link to page 8 link to page 8 link to page 8 link to page 8 link to page 39 link to page 33 link to page 33
AIS2IH Temperature sensor characteristics 2.3 Temperature sensor characteristics
@ Vdd = 3.0 V, T = -40 °C to +115 °C unless otherwise noted
Table 5. Temperature sensor characteristics Symbol Parameter Min. Typ. (1) Max. Unit
Top Operating temperature range -40 +115 °C Toff Temperature offset(2) -15 +15 °C 1(3) TSDr Temperature sensor output change vs. temperature LSB/°C 16(4) Temperature refresh rate in High-Performance Mode for all ODRs 50 or in low-power modes for ODRs equal to 200/100/50 Hz TODR Temperature refresh rate in low-power modes for ODR equal to 25 Hz 25 Hz Temperature refresh rate in low-power modes for ODR equal to 12.5 Hz 12.5 Temperature refresh rate in low-power modes for ODR equal to 1.6 Hz 1.6 1. Typical specifications are not guaranteed. 2. The output of the temperature sensor is 0 LSB (typ.) at 25 °C. 3. 8-bit resolution (i.e. when using the OUT_T (26h) register) 4. 12-bit resolution (i.e. when using the OUT_T_L (0Dh) and OUT_T_H (0Eh) registers)
DS12421
Rev 4 page 8/63
Document Outline Features Applications Description 1 Block diagram and pin description 1.1 Block diagram 1.2 Pin description 2 Mechanical and electrical specifications 2.1 Mechanical characteristics 2.2 Electrical characteristics 2.3 Temperature sensor characteristics 2.4 Communication interface characteristics 2.4.1 SPI - serial peripheral interface 2.4.2 I²C - inter-IC control interface 2.5 Absolute maximum ratings 3 Terminology and functionality 3.1 Terminology 3.1.1 Sensitivity 3.1.2 Zero-g level offset 3.2 Functionality 3.2.1 Operating modes 3.2.2 Single data conversion on-demand mode 3.2.3 Self-test 3.2.4 Activity/Inactivity, stationary/motion detection functions 3.2.5 High tap/double-tap user configurability 3.2.6 Offset management 3.3 Sensing element 3.4 IC interface 3.5 Factory calibration 3.6 Temperature sensor 4 Application hints 5 Digital main blocks 5.1 Block diagram of filters 5.2 Data stabilization time vs. ODR/device setting 5.3 FIFO 5.3.1 Bypass mode 5.3.2 FIFO mode 5.3.3 Continuous mode 5.3.4 Continuous-to-FIFO mode 5.3.5 Bypass-to-Continuous mode 6 Digital interfaces 6.1 I²C serial interface 6.1.1 I²C operation 6.2 SPI bus interface 6.2.1 SPI read 6.2.2 SPI write 6.2.3 SPI read in 3-wire mode 7 Register mapping 8 Register description 8.1 OUT_T_L (0Dh) 8.2 OUT_T_H (0Eh) 8.3 WHO_AM_I (0Fh) 8.4 CTRL1 (20h) 8.5 CTRL2 (21h) 8.6 CTRL3 (22h) 8.7 CTRL4_INT1_PAD_CTRL (23h) 8.8 CTRL5_INT2_PAD_CTRL (24h) 8.9 CTRL6 (25h) 8.10 OUT_T (26h) 8.11 STATUS (27h) 8.12 OUT_X_L (28h) 8.13 OUT_X_H (29h) 8.14 OUT_Y_L (2Ah) 8.15 OUT_Y_H (2Bh) 8.16 OUT_Z_L (2Ch) 8.17 OUT_Z_H (2Dh) 8.18 FIFO_CTRL (2Eh) 8.19 FIFO_SAMPLES (2Fh) 8.20 TAP_THS_X (30h) 8.21 TAP_THS_Y (31h) 8.22 TAP_THS_Z (32h) 8.23 INT_DUR (33h) 8.24 WAKE_UP_THS (34h) 8.25 WAKE_UP_DUR (35h) 8.26 FREE_FALL (36h) 8.27 STATUS_DUP (37h) 8.28 WAKE_UP_SRC (38h) 8.29 TAP_SRC (39h) 8.30 SIXD_SRC (3Ah) 8.31 ALL_INT_SRC (3Bh) 8.32 X_OFS_USR (3Ch) 8.33 Y_OFS_USR (3Dh) 8.34 Z_OFS_USR (3Eh) 8.35 CTRL7 (3Fh) 9 Package information 9.1 Soldering information 9.2 LGA-12 package information 9.3 LGA-12 packing information Revision history Contents List of tables List of figures
