Datasheet HPR-1100BGH (Excelitas) - 6
ManufacturerExcelitas
DescriptionHybrid PIN Receiver Module
Pages / Page7 / 6 — HPR Series – HPR-1100BGH. Hybrid PIN Receiver Module. Information. …
File Format / SizePDF / 465 Kb
HPR Series – HPR-1100BGH. Hybrid PIN Receiver Module. Information. Storage and handling. Testing methods. Packaging and shipping
HPR Series – HPR-1100BGH Hybrid PIN Receiver Module Information Storage and handling Testing methods Packaging and shipping
Excelitas Technologies’ Hybrid PIN Receiver Module HPR-1100BGH provides high output signals at highest signal-to-noise-ratio (SNR). Specially designed with integrated components as a J-FET operational amplifier and our high-speed Silicon PIN Photodiode it is well suited for systems where weak signals with a high gain need to be amplified at low-bandwidth. Recognizing that different applications have different performance requirements, Excelitas offers a wide range of customization of these photodiodes to meet your design challenges. Responsivity and noise screening, custom device testing, TEC cooled devices and incorporating band pass filters are among many of the application-specific solutions available.
Excelitas highly recommends to follow the below notes: - Keep devices in an ESD controlled environment until final assembly. - Keep package trays closed until final assembly. - Remove Devices from their trays by using a vacuum pick-up tool (if applicable) - If a manual picking method is necessary, use a vacuum pick or non-metallic tweezer. - Do not make contact to the window surface
Testing methods
Excelitas verifies the electro optical specifications on every device. Visual inspection during fabrication is performed as per our quality standard and failed devices are removed. Excelitas Technologies is certified to meet ISO-9001 and the photodiode are designed to meet MIL-STD-883 and/or MIL-STD-750 specifications.
All Hybrid PIN Receivers are shipped in ESD safe plastic trays. www.excelitas.com Page 6 of 7 HPR Series - HPR-1100BGH_Rev.2021.04
