Datasheet VCNL36825T (Vishay) - 9
ManufacturerVishay
DescriptionProximity Sensor With Interrupt, VCSEL, and I2C Interface
Pages / Page16 / 9 — VCNL36825T. Command Register Format. TABLE 2 - REGISTER: PS_CONF1_L …
File Format / SizePDF / 238 Kb
VCNL36825T. Command Register Format. TABLE 2 - REGISTER: PS_CONF1_L DESCRIPTION REGISTER NAME
VCNL36825T Command Register Format TABLE 2 - REGISTER: PS_CONF1_L DESCRIPTION REGISTER NAME
VCNL36825T
VCNL36825T provides an 8-bit command register for PS controlling independently. The description of each command format is shown in following tables.
TABLE 2 - REGISTER: PS_CONF1_L DESCRIPTION REGISTER NAME COMMAND CODE: 0x00_L (0x00 DATA BYTE LOW)
Command Bit Description PS_CAL 7 Must be set to “1” when power on ready Reserved 6 : 2 Default = (0 : 0 : 0 : 0 : 0) Set this bit = “1” to enable bias circuit PS_ON 1
Note
• Initialization process: step 1: PS_ON = “1”; step 2: set PS_CAL = “1” Reserved 0 Default = 1, must always stay = 1
TABLE 3 - REGISTER: PS_CONF1_H DESCRIPTION REGISTER NAME COMMAND CODE: 0x00_H (0x00 DATA BYTE HIGH)
Command Bit Description Reserved 15 : 10 Default = (0 : 0 : 0 : 0 : 0 : 0) Reserved 9 Must be set to “1” when power on ready Reserved 8 Default = 0
TABLE 4 - REGISTER: PS_CONF2_L DESCRIPTION REGISTER NAME COMMAND CODE: 0x03_L (0x03 DATA BYTE LOW)
Command Bit Description (0 : 0) = 10 ms, (0 : 1) = 20 ms, (1 : 0) = 40 ms, (1 : 1) = 80 ms PS_PERIOD 7 : 6 PS measurement period setting (0 : 0) = 1, (0 : 1) = 2, (1 : 0) = 3, (1 : 1) = 4 PS_PERS 5 : 4 PS interrupt persistence setting PS_ INT 3 : 2 (0 : 0) = interrupt disable, (0 : 1) = logic high / low mode, (1 : 0) = first high, (1 : 1) = interrupt enable PS_SMART_PERS 1 0 = disable smart persistence, 1 = enable smart persistence PS_ST 0 0 = PS start, 1 = PS stop, default = 1; for active force mode set AF = 1 before setting PS_ST = 0
TABLE 5 - REGISTER: PS_CONF2_H DESCRIPTION COMMAND CODE: 0x03_H (0x03 DATA BYTE HIGH)
Command Bit Description PS_IT 15 : 14 (0 : 0) = 1T, (0 : 1) = 2T, (1 : 0) = 4T, (1 : 1) = 8T (0 : 0 ) = 1, (0 : 1) = 2, (1 : 0) = 4, (1 : 1) = 8; PS_MPS 13 : 12 PS multi-pulse setting PS_ITB 11 0: ITB = 25 μs, 1: ITB = 50 μs PS_HG 10 0 = disable, 1 = enable, PS high gain mode Reserved 9 : 8 Default = (0 : 0) Rev. 1.2, 22-Mar-2021
9
Document Number: 80235 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
