Datasheet IGI60F1414A1L (Infineon)
ManufacturerInfineon
DescriptionCoolGaN IPS half-bridge 600 V
Pages / Page2 / 1 — Block diagram IGI60F1414A1L. Functional isolation. CoolGaN™
File Format / SizePDF / 336 Kb
Datasheet IGI60F1414A1L Infineon
Product brief CoolGaN™ IPS half-bridge 600 V Ease of use with integrated drivers for highest efficiency and power density Infineon’s CoolGaN™ Integrated Power Stage (IPS) 600 V leverages the market’s most Key features reliable GaN technology, uniting ultimate efficiency and reliability with ease of use. The IGI60F1414A1L combines a half-bridge power stage consisting of two 140 mΩ ›Isolated digital input with digital-in, (typ. RDS(on)) / 600 V enhancement-mode CoolGaN™ switches with dedicated gate drivers power-out building block in a thermally enhanced 8x8 mm QFN-28 package. ›Application configurable switching behavior By using two digital PWM inputs, the device enables an easy-to-use digital-in-to-power- ›Fast, highly accurate, out solution, ideally suited to support the design of compact appliances in the low-to- and stable timing medium power area (30-500 W). ›Thermally enhanced 8x8mm QFN-28 and 6x8mm QFN-26 packages The integrated isolation function, the clean separation of digital and power ground and the reduced complexity of the PCB layout are crucial in achieving shorter development time, lower system bill-of-material and lower total cost. Both the gate driver’s input-to-output Key benefits isolation and the level-shifting to the high-side are based on Infineon’s proven on-chip coreless transformer (CT) technology that guarantees high speed and excellent robustness ›Easy to drive with 2x digital even for extremely fast switching transients with voltage slopes exceeding 150 V/ns. PWM input ›Low system BOM ›Complete configurability of
gate path via simple RC circuit VDDH OUTH GH DH ›Allows short dead-time setting to maximize system efficiency  VDDI CT UVLO UVLO DH ›Small package for compact system designs Tx Rx SLDON SLDO Logic INL SH Control SW
logic
CoolGaN™
INH UVLO DL ENABLE Tx Rx Logic SL GNDI VDDL OUTL OUTL SL www.infineon.com/coolgan-ips
