Datasheet IGI60F1414A1L (Infineon) - 2
Manufacturer | Infineon |
Description | CoolGaN IPS half-bridge 600 V |
Pages / Page | 2 / 2 — Pin configuration and exposed pads for. Pin description. QFN-28 8 x 8 mm … |
File Format / Size | PDF / 336 Kb |
Pin configuration and exposed pads for. Pin description. QFN-28 8 x 8 mm package, top view (not to scale). Pin number Symbol
Product brief CoolGaN™ IPS half-bridge 600 V Ease of use with integrated drivers for highest efficiency and power density
Pin configuration and exposed pads for Pin description QFN-28 8 x 8 mm package, top view (not to scale) Pin number Symbol Description 1
– Do not connect (floating)
2
OUTH Driver output high-side SW NC ENABLE GNDI VDDI SLDON INH
3
VDDH Supply voltage for high-side driver (typ. 8 V referred to SW) 28 27 26 25 24 23 22
4
GH Gate connection high-side switch NC 1 21 INL
5-8, 28
SW Half-bridge output (switching node) GNDI OUTH 2 20 GNDI
9-11
DH Drain connection high-side switch
12-16
SL Source connection low-side switch VDDH 3 19 OUTL
17
GL Gate connection low-side switch GH 4 18 VDDL
18
VDDL Supply voltage for low-side driver (typ. 8 V referred to SL) SW 5 17 GL
19
OUTL Driver output low-side SW SW 6 16 SL
20, 25
GNDI Ground connection of driver Input stage SL SW 7 15 SL
21
INL Input signal (default state “Low”); controls low-side switch
22
INH Input signal (default state “Low”): controls high-side switch SW 8 14 SL
23
SLDON Connected to VDDI (or not connected): VDDI directly supplies 13 SL driver input circuitry Connected to GNDI: Internal shunt regulator activated to generate VDDI (3.3 V) 9
24
VDDI Supply voltage driver input stage (+3.3 V); can be either applied 10 11 12 directly or generated by internal SLDO (e.g by connecting VDDI via resistor R DH DH DH SL VDD1 to VDDL)
26
ENABLE Input signal (default state “Low” - both outputs set to low slate); logic “High” required to activate outputs
27
CoolGaN™ IPS half-bridge 600 V product portfolio RDS(on) typ. 8x8mm QFN-28 package 6x8mm QFN-26 package 140 mΩ
IGI60F1414A1L
200 mΩ
IGI60F2020A1L
270 mΩ
IGI60F2727A1L IGI60F2727A1M
500 mΩ
IGI60F5050A1L Sampling/available Published by
Please note! Additional information
Infineon Technologies Austria AG This Document is for information purposes only and any For further information on technologies, our products, the 9500 Villach, Austria information given herein shall in no event be regarded as a application of our products, delivery terms and conditions warranty, guarantee or description of any functionality, and/or prices, please contact your nearest Infineon Technologies © 2021 Infineon Technologies AG. conditions and/or quality of our products or any suitability for a office (www.infineon.com). All Rights Reserved. particular purpose. With regard to the technical specifications of our products, we kindly ask you to refer to the relevant product
Warnings
data sheets provided by us. Our customers and their technical Due to technical requirements, our products may contain departments are required to evaluate the suitability of our dangerous substances. For information on the types in question, products for the intended application. please contact your nearest Infineon Technologies office. We reserve the right to change this document and/or the Except as otherwise explicitly approved by us in a written information given herein at any time. document signed by authorized representatives of Infineon Technologies, our products may not be used in any life- endangering applications, including but not limited to medical, nuclear, military, life-critical or any other applications where a Document number: B152-I1170-V1-7600-AP-EC-P failure of the product or any consequences of the use thereof Date: 05 / 2021 can result in personal injury.
