Datasheet 2N3819 (ON Semiconductor)
Manufacturer | ON Semiconductor |
Description | N-Channel RF Amplifier |
Pages / Page | 3 / 1 — 2N38. 2N3819. N-Channel RF Amplifier. Epitaxial Silicon Transistor. … |
File Format / Size | PDF / 57 Kb |
2N38. 2N3819. N-Channel RF Amplifier. Epitaxial Silicon Transistor. Absolute Maximum Ratings*. Symbol. Parameter. Ratings. Units. NOTES:
www.DataSheet4U.com
2N38 19 2N3819 N-Channel RF Amplifier
• This device is designed for RF amplifier and mixer applications operating up to 450MHz, and for analog switching requiring low capacitance. • Sourced from process 50. TO-92 1 1. Drain 2. Gate 3. Source
Epitaxial Silicon Transistor Absolute Maximum Ratings*
TC=25°C unless otherwise noted
Symbol Parameter Ratings Units
VDG Drain-Gate Voltage 25 V VGS Gate-Source Voltage -25 V ID Drain Current 50 mA IGF Forward Gate Current 10 mA TSTG Storage Temperature Range -55 ~ 150 °C * This ratings are limiting values above which the serviceability of any semiconductor device may be impaired.
NOTES:
1) These rating are based on a maximum junction temperature of 150 degrees C. 2) These are steady limits. The factory should be consulted on applications involving pulsed or low duty cycle operations.
Electrical Characteristics
Symbol Parameter Test Condition Min. Typ. Max. Units Off Characteristics
V(BR)GSS Gate-Source Breakdwon Voltage IG = 1.0µA, VDS = 0 25 V IGSS Gate Reverse Current VGS = -15V, VDS = 0 2.0 nA VGS(off) Gate-Source Cutoff Voltage VDS = 15V, ID = 2.0nA 8.0 V VGS Gate-Source Voltage VDS = 15V, ID = 200µA -0.5 -7.5 V
On Characteristics
IDSS Zero-Gate Voltage Drain Current VDS = 15V, VGS = 0 2.0 20 mA
Small Signal Characteristics
gfs Forward Transfer Conductance VDS = 15V, VGS = 0, f = 1.0KHz 2000 6500 µmhos goss Output Conductance VDS= 15V, VGS = 0, f = 1.0KHz 50 µmhos yfs Forward Transfer Admittance VDS= 15V, VGS = 0, f = 1.0KHz 1600 µmhos Ciss Input Capacitance VDS = 15V, VGS = 0, f = 1.0KHz 8.0 pF Crss Reverse Transfer Capacitance VDS = 15V, VGS = 0, f = 1.0KHz 4.0 pF
Thermal Characteristics
TA=25°C unless otherwise noted
Symbol Parameter Max. Units
PD Total Device Dissipation 350 mW Derate above 25°C 2.8 mW/°C RθJC Thermal Resistance, Junction to Case 125 °C/W RθJA Thermal Resistance, Junction to Ambient 357 °C/W * Device mounted on FR-4 PCB 1.5” × 1.6” × 0.06” ©2002 Fairchild Semiconductor Corporation Rev. A1, December 2002
