Datasheet L99VR01 (STMicroelectronics) - 9
DescriptionAutomotive Linear Voltage Regulator with Configurable Output Voltage having 200mA current capability
Pages / Page47 / 9 — L99VR01. Electrical characteristics. Item. Pin. Symbol. Parameter. Test …
File Format / SizePDF / 3.9 Mb
L99VR01. Electrical characteristics. Item. Pin. Symbol. Parameter. Test condition. Min. Typ . Max. Unit. DS13649. Rev 2. page 9/47
L99VR01 Electrical characteristics Item Pin Symbol Parameter Test condition Min Typ  Max Unit DS13649 Rev 2 page 9/47
link to page 10 link to page 10 link to page 10 link to page 10 link to page 10
L99VR01 Electrical characteristics Item Pin Symbol Parameter Test condition Min. Typ . Max. Unit
IO = 1 mA to 100 mA Static load regulation (4) VO= 3.3 V for VS=5 V; 1 % VO= 5 V for VS= 6 V A.013 VO ∆VO / VO IO = 10 mA to 100 mA, Tr, f=10 us V Dynamic load regulation(3) (4) O=3.3 V for 3 % VS=5 V; VO= 5 V for VS= 6 V IO = 150 mA VO = 5 V IO = 150 mA VO = 3.3 V IO = 150 mA 500 mV VO = 2.8 V IO = 150 mA VO = 2.5 V IO = 150 mA VO = 1.8 V A.014 VS, VO Vdp Drop voltage (5) IO = 200 mA VO = 5 V IO = 200 mA VO = 3.3 V IO = 200 mA 530 mV VO = 2.8 V IO = 200 mA VO = 2.5 V IO = 200 mA VO = 1.8 V VS = 13.5 V; VO = 5 V; IO A.015 VS, VO PSRR Power supply rejection ratio = 200 mA 75(3) dB fr = 1 kHz Current consumption with VS = 3.5V; 13.5 V, EN = A.017 VS, VO Iqn regulator disabled Iqn = IS – 1 µA low IO Current consumption with V A.058 V S = 3.5 V; 13.5 V, IO = 0 S, VO Iqn_LL regulator enabled Iqn_LL= IS 75 100 µA – I µA; EN = high O Current consumption with V A.018 V S = 3.5 V; 13.5 V, 0 < IO S, VO Iqn_O regulator enabled 100 130 µA I ≤100 µA; EN = high qn_O = Is – IO Current consumption with VS = 3.5 V; 13.5 V, IO = A.019 VS, VO Iqn_50 regulator enabled 50 mA 1 1.3 mA Iqn_50 = Is – IO EN = high Current consumption with V A.020 V S = 3.5 V; 13.5 V, IO= S, VO Iqn_100 regulator enabled 1.7 2.0 mA I 100 mA EN = high qn_100 = Is – IO Current consumption with V A.021 V S = 3.5 V; 13.5 V, IO= S, VO Iqn_200 regulator enabled 3.1 3.5 mA I 200 mA EN = high qn_200 = Is – IO
DS13649
Rev 2 page 9/47
Document Outline Cover image Product status link / summary Features Description 1 Block diagram and pins description 2 Electrical specifications 2.1 Absolute maximum ratings 2.2 Thermal data 2.2.1 Thermal resistance 2.2.2 Thermal protection 2.3 Electrical characteristics 2.4 Electrical characteristics curves 3 Test circuit and waveforms plot 3.1 Load regulation 4 Application information 4.1 Voltage regulator 4.2 Output current limitation 4.3 Output voltage selection 4.4 Enable 4.5 Reset 4.6 Autonomous watchdog 4.7 Thermal warning and thermal shutdown 4.8 Overvoltage detection by advanced thermal warning read-out 4.9 Fast output discharge 4.10 Undervoltage lockout UVLO 4.11 Functional safety management 5 Application 6 Package and PCB thermal data 6.1 PowerSSO-12 Thermal data 6.2 SO-8 thermal data 7 Package information 7.1 PowerSSO-12 package information 7.2 SO-8 package information 7.3 PowerSSO-12 packaging information 7.4 SO-8 packaging information 8 Order codes Revision history Contents List of tables List of figures
