Datasheet L99VR01 (STMicroelectronics) - 10
DescriptionAutomotive Linear Voltage Regulator with Configurable Output Voltage having 200mA current capability
Pages / Page47 / 10 — L99VR01. Electrical characteristics. Item. Pin. Symbol. Parameter. Test …
File Format / SizePDF / 3.9 Mb
L99VR01. Electrical characteristics. Item. Pin. Symbol. Parameter. Test condition. Min. Typ . Max. Unit. Table 6. Fast output discharge. Typ
L99VR01 Electrical characteristics Item Pin Symbol Parameter Test condition Min Typ  Max Unit Table 6 Fast output discharge Typ
link to page 17
L99VR01 Electrical characteristics Item Pin Symbol Parameter Test condition Min. Typ . Max. Unit
VO= 0.8 V; 1.2 V; 1.5 V; 1.5 1.6 1.7 1.8 V A.022 VS VUVLO_fall Undervoltage lockout, falling V VO = 2.5 V; 2.8 V; 3.3 V 2.3 2.4 2.55 VO = 5 V 4.6 4.8 4.9 VO = 0.8 V; 1.2 V; 1.5 V; 1.7 1.8 2.1 1.8 V A.023 VS VUVLO_ rise Undervoltage lockout, rising V VO=2.5 V; 2.8 V; 3.3 V 2.6 2.7 2.8 VO=5 V 4.9 5.1 5.3 1. Ishort typical value of 120 mA for t= 400 µs during the power on 2. Vs_Low = 3.5 V@VO = 0.8 V, 1.2 V,1.5 V,1.8 V& 2.5 V; Vs_Low=5 V@ VO= 2.8 V & 3.3 V, Vs_Low= 6 V@VO = 5 V 3. Parameters are guaranteed by design 4. Referred to Figure 30. Maximum load variation response 5. Considering that the minimum operating input voltage is 2.15 V, the dropout voltage (Vdp) is not defined for output voltages below 1.8 V.
Table 6. Fast output discharge Item Pin Symbol Parameter Test condition Min. Typ. Max. Unit
V Fast discharge - pull S= 3.95 V; 13.5 V; VO = A.024 VO RFD 3.3 V, V 50 75 105 Ω down resistor O = 5 V EN = low
Table 7. Reset Item Pin Symbol Parameter Test condition Min. Typ. Max. Unit
VS = 5 V; 13.5 V 0.2 x A.025 RST Vrst_l Reset output low voltage Rext ≥ 4.7 KΩ to VO V V O VO = 3.3 V, VO = 5 V Reset output high A.026 RST Irst_lkg V leakage current rst = 0.8 V 1 µA VS = 5 V; 13.5 V V VO decreasing Below A.027 RST V O out of regulation – low O_th 13.5% 10% 6.5% threshold V V O=3.3 V, O VO=5 V V V S = 5 V; 13.5 V; VO A.055 RST V O out of regulation – low O_th_hyst increasing; V 2% V threshold hysteresis O=3.3 V ; O_th VO=5 V V A.028 RST T S = 5 V; 13.5 V; VO=3.3 rr Reset reaction time 10 16 37 µs V ; VO=5 V V A.029 RST T S = 5 V; 13.5 V ; VO=3.3 rd Reset delay time 160 250 300 µs V ; VO = 5 V
DS13649
Rev 2 page 10/47
Document Outline Cover image Product status link / summary Features Description 1 Block diagram and pins description 2 Electrical specifications 2.1 Absolute maximum ratings 2.2 Thermal data 2.2.1 Thermal resistance 2.2.2 Thermal protection 2.3 Electrical characteristics 2.4 Electrical characteristics curves 3 Test circuit and waveforms plot 3.1 Load regulation 4 Application information 4.1 Voltage regulator 4.2 Output current limitation 4.3 Output voltage selection 4.4 Enable 4.5 Reset 4.6 Autonomous watchdog 4.7 Thermal warning and thermal shutdown 4.8 Overvoltage detection by advanced thermal warning read-out 4.9 Fast output discharge 4.10 Undervoltage lockout UVLO 4.11 Functional safety management 5 Application 6 Package and PCB thermal data 6.1 PowerSSO-12 Thermal data 6.2 SO-8 thermal data 7 Package information 7.1 PowerSSO-12 package information 7.2 SO-8 package information 7.3 PowerSSO-12 packaging information 7.4 SO-8 packaging information 8 Order codes Revision history Contents List of tables List of figures
