Datasheet PC817 (First Silicon)
Manufacturer | First Silicon |
Description | 1-Сhannel Transistor Output Type Photo Coupler |
Pages / Page | 4 / 1 — SEMICONDUCTOR. PC817. TECHNICAL DATA. 1-CHANNEL TRANSISTOR OUTPUT TYPE … |
File Format / Size | PDF / 137 Kb |
SEMICONDUCTOR. PC817. TECHNICAL DATA. 1-CHANNEL TRANSISTOR OUTPUT TYPE PHOTO COUPLER
SEMICONDUCTOR PC817 TECHNICAL DATA 1-CHANNEL TRANSISTOR OUTPUT TYPE PHOTO COUPLER
PC817 The PC817 Series contains a light emitting diode optically coupled to a phototransistor. Input-output isolation voltage is 5000Vrms. Response 6.5 0.5 time(tr) is typically 4us and minimum CTR is 50% at input current of + _ 5mA. FEATURES 4.6 0.5 + _ 7.62 0.3 + _ Collector-Emitter Voltage : Min.80V 3.5 0.5 + _ Current Transfer Ratio 0.5TYP. (CTR : MIN. 50% at I 3.3 0.5 F=5mA, VCE=5V). + _ _ + 0.26 High isolation voltage between input and output. 2.8 0.5 0.5 0.1 _ 7.62~9.98 (VISO=5,000Vrms) 2.54 0.25 _ DIP-4 PC817M APPLICATIONS Feedback circuit in power supply. 6.5 0.5 + _ Switching Mode Power Supply. System appliances, Measuring instruments. Registers, Copiers, Automatic vending machines. Electric home applicances such as fan heaters, etc. 4.6 0.5 _ 7.62 0.3 _ 3.5 0.5 + _ 6.9 0.5 + _ _ + _ + 0.26 2.8 0.5 2.3 0.5 BLOCK DIAGRAM AND PIN CONFIGURATIONS (TOP VIEW) 10.16 0.5 _ 0.5 0.1 _ 2.54 0.25 _ 1 4 1. ANODE DIP-4 (M) 2. CATHODE 3. EMITTER PC817S 2 3 4. COLLECTOR 6.5 0.5 + _ RANK TABLE OF CURRENT TRANSFER RATIO(CTR) RANK MARK CTR (%) TEST CONDITION 4.6 0.5 _ 7.62 0.3 _ (None) 50~600 3.5 0.5 + _ A 80~160 0.26 0.1 + _ 0.35 +0.25/-0.30 1 0.25 _ 1.2 0.1 _ B 130~260 2.54 0.25 _ 10.16 0.5 _ IF=5mA, VCE=5V, Ta=25 C 200~400 D 300~600 L 50~100 DIP-4(S) 2016. 07. 30 Revision No : 0 1/4
