Datasheet G2RL (Omron) - 4
ManufacturerOmron
DescriptionLow profile power relay with 15.7 mm height
Pages / Page8 / 4 — PCB Power Relay. Engineering Data. Maximum Switching Capacity. 1-pole …
PCB Power Relay. Engineering Data. Maximum Switching Capacity. 1-pole Standard Type. 1-pole High-capacity Type. 2-pole Type
PCB Power Relay Engineering Data Maximum Switching Capacity 1-pole Standard Type 1-pole High-capacity Type 2-pole Type
G2RL
G2RL
PCB Power Relay
Engineering Data
50 50 50 AC resistive load AC resistive load AC resistive load 10 10 10 Switching current (A) 5 Switching current (A) 5 Switching current (A) 5 DC resistive DC resistive DC resistive load load load 1 1 1 0.5 0.5 0.5 0.1 0.1 0.1 0 5 10 20 30 50 100 500 1,000 0 5 10 20 30 50 100 500 1,000 0 5 10 20 30 50 100 500 1,000 Switching voltage (V) Switching voltage (V) Switching voltage (V) ●
Ambient Temperature vs. Rated
Ambient Temperature vs. Maximum High-sensitibity Type Carry Current Coil Voltage
) 50 20 250 (% 1-pole High-capacity type oltage G AC resistive load y Current (A) 16 200 15 2 10 1-pole Standard type 180 G2RL-1A-E-CV um coil v R Switching current (A) 5 L Rated Carr 12 150 DC resistive 1-pole High-sensitivity type Maxim load 10 130 110 8 100 1 2-pole type Other type 0.5 5 50 0.1 0 5 10 20 30 50 100 500 1,000 0 10 20 30 40 50 60 70 80 85 90 100 0 10 20 30 40 50 60 70 80 85 90 100 105 110 Switching voltage (V) Ambient temperature (°C) Ambient temperature (°C) Note. The maximum coil voltage refers to the maximum value in a varying range of operating power voltage, not a continuous voltage. ●
Ambient Temperature vs. Must Operate and Must Release Voltages
100 Sample: Must operate voltage oltage 90 G2RL-14-E 24 VDC Must release voltage Number of relays: 5 pcs oltage) (%) 80 max. X ated v 70 min. ust release v 60 ate/m 50 (percentage of r 40 Must oper max. 30 X min. 20 10 0 20 40 60 80 100 120 Ambient temperature (°C)
4
