Datasheet G2RL (Omron) - 3
ManufacturerOmron
DescriptionLow profile power relay with 15.7 mm height
Pages / Page8 / 3 — PCB Power Relay. Characteristics. Flux Protection Type
PCB Power Relay Characteristics Flux Protection Type
G2RL
G2RL
PCB Power Relay
Characteristics
Classification Standard type High-capacity type High-sensitivity type Item Number of poles 1-pole 2-pole 1-pole Contact resistance *1 100 mΩ max. Operate time 15 ms max. Release time 5 ms max. Insulation resistance *2 1,000 MΩ min. Between coil and 5,000 VAC, 50/60 Hz for 1min contacts Between contacts Dielectric of the same 1,000 VAC, 50/60 Hz for 1min strength polarity Between contacts of different polarity − 2,500 VAC, 50/60 Hz for 1min − Impulse withstand voltage 10 kV (1.2 x 50 μs) Vibration Destruction 10 to 55 to 10 Hz, 0.75 mm single amplitude (1.5 mm double amplitude) resistance Malfunction 10 to 55 to 10 Hz, 0.75 mm single amplitude (1.5 mm double amplitude) Shock Destruction 1,000 m/s2 resistance Malfunction Energized: 100 m/s2, De-energized: 100 m/s2 Mechanical 20,000,000 operations (at 18,000 operations/hr) G2RL-1A-E(-ASI, -HA, -PW1), G2RL-1-E(-ASI, -HA, -PW1): G2RL-2(A)(-HA, -PW1), Durability G2RL-1A, G2RL-1(-HA, -PW1): 30,000 operations at 250 VAC, 16 A Electrical *3 G2RL-2-ASI: G2RL-1(A)-H: 50,000 operations at 250 VAC, 12 A 30,000 operations at 24 VDC, 16 A (resistive load) 30,000 operations at 250 VAC, 8 A 50,000 operations at 250 VAC, 10 A 30,000 operations at 24 VDC, 12 A G2RL-1A-E-CV(-HA): 30,000 operations at 30 VDC, 8 A 50,000 operations at 250 VAC, 16 A G at 105°C 2 -40°C to 85°C (with no icing or condensation) Ambient operating temperature R -40°C to 105°C (with no icing or condensation) by G2RL-1A-E-CV L Ambient operating humidity 5% to 85% (with no icing or condensation) Weight Approx. 12 g Note 1. Values in the above table are the initial values at 23°C. Note 2. Contact your OMRON sales representative for sealed models. *1. Measurement conditions: 5 VDC, 1 A, voltage drop method *2. Measurement conditions: Measured at the same points as the dielectric strength using a 500 VDC ohmmeter. *3. 1,800 operations per hour.
3
