Datasheet G2RL (Omron) - 2
ManufacturerOmron
DescriptionLow profile power relay with 15.7 mm height
Pages / Page8 / 2 — PCB Power Relay. Ordering Information. Ratings. Coil. Contacts: Flux …
PCB Power Relay. Ordering Information. Ratings. Coil. Contacts: Flux Protection Type
PCB Power Relay Ordering Information Ratings Coil Contacts: Flux Protection Type
G2RL
G2RL
PCB Power Relay
Terminal Shape Market Code Classification Contact Form Enclosure Rating Model Rated Coil Voltage Minimum Packing Unit G2RL-1A 5, 12, 24, 48 VDC Flux protection SPST-NO (1a) G2RL-1A-PW1 5, 12, 24 VDC Sealed G2RL-1A4 5, 12, 24, 48 VDC G2RL-1 Flux protection SPDT (1c) G2RL-1-PW1 5, 12, 24 VDC Sealed G2RL-14 5, 12, 24, 48 VDC Standard G2RL-2A Flux protection DPST-NO (2a) G2RL-2A-PW1 5, 12, 24 VDC Sealed G2RL-2A4 G2RL-2 5, 12, 24, 48 VDC Flux protection G2RL-2-ASI DPDT (2c) General G2RL-2-PW1 5, 12, 24 VDC Purpose Sealed G2RL-24 G2RL-1A-E 5, 12, 24, 48 VDC G2RL-1A-E-ASI PCB terminals Flux protection 20 pcs/tube SPST-NO (1a) G2RL-1A-E-CV 5, 12, 24 VDC G2RL-1A-E-PW1 High-capacity Sealed G2RL-1A4-E G2RL-1-E 5, 12, 24, 48 VDC Flux protection G2RL-1-E-ASI SPDT (1c) G2RL-1-E-PW1 5, 12, 24 VDC Sealed G2RL-14-E 5, 12, 24, 48 VDC G SPST-NO (1a) G2RL-1A-H 2 High-sensitivity SPDT (1c) G2RL-1-H R L SPDT (1c) G2RL-1-HA Standard DPST-NO (2a) G2RL-2A-HA Flux protection 5, 12, 24 VDC Home DPDT (2c) G2RL-2-HA Application G2RL-1A-E-HA SPST-NO (1a) High-capacity G2RL-1A-E-CV-HA SPDT (1c) G2RL-1-E-HA Note 1. When ordering, add the rated coil voltage to the model number. Example: G2RL-1A DC5 Rated coil voltage However, the notation of the coil voltage on the product case will be marked as @@VDC. Note 2. Place your order in tube (20 pcs/tube) units. Note 3. Contact your OMRON sales representative for sealed models. ■
Ratings
Coil
Item Must operate voltage Must release voltage Max. voltage Rated current Coil resistance (V) (V) (V) Power consumption (mA) (Ω) (mW) Rated voltage % of rated voltage 5 VDC 80.0 62.5 Standard, Approx. 400 12 VDC 33.3 360 10% min. High- 70% max. Approx. 100* 24 VDC 16.7 1,440 10 to 32%* capacity 130% 48 VDC 8.96 5,358 Approx. 430 (at 85°C) 5 VDC 50 96 High- 12 VDC 20.8 576 75% max. 10% Approx. 250 sensitivity 24 VDC 10.42 2,304 Note 1. The rated current and coil resistance are measured at a coil temperature of 23°C with a tolerance of ±10%. Note 2. The operating characteristics are measured at a coil temperature of 23°C. Note 3. The “max. voltage” is the maximum voltage that can be applied to the relay coil. * These numbers are only for -PW1 type. Power consumption with holding voltage is approx.120mW. Please confirm the detail in page 6 coil voltage reduction (holding voltage). ●
Classification Standard type (resistive load) High-capacity type (resistive load) High-sensitivity type (resistive load) Item Model 1-pole 2-pole 1-pole Contact type Single Contact material Ag-alloy (Cd free) 12 A at 250 VAC 8 A at 250 VAC 16 A at 250 VAC Rated load 10 A at 250 VAC (See note) 12 A at 24 VDC (See note) 8 A at 30 VDC (See note) 16 A at 24 VDC (See note) Rated carry current 12 A (See note) 8 A (70°C)/5 A (85°C) (See note) 16 A (See note) 10 A (See note) Max. switching voltage 440 VAC, 300 VDC Max. switching current 12 A 8 A 16 A 10 A Failure rate (P level) 40 mA at 24 VDC (reference value*) * This value was measured at a switching frequency of 120 operations/min. Note: Contact your OMRON representative for the ratings on sealed models.
2
