Datasheet L165 (STMicroelectronics) - 3
Description3A Power Operational Amplifier
Pages / Page9 / 3 — L165. ELECTRICAL CHARACTERISTCS. Symbol. Parameter. Test Condition. Min. …
File Format / SizePDF / 145 Kb
L165. ELECTRICAL CHARACTERISTCS. Symbol. Parameter. Test Condition. Min. Typ. Max. Unit
L165 ELECTRICAL CHARACTERISTCS Symbol Parameter Test Condition Min Typ Max Unit
(VS = ± 15 V, Tj = 25 °C unless otherwise specified)
Symbol Parameter Test Condition Min. Typ. Max. Unit
VS Supply Voltage ± 6 ± 18 V Id Quiescent Drain Current VS = ±18 V 40 60 mA Ib Input Bias Current 0.2 1 µA Vos Input Offset Voltage ± 2 ± 10 mV Ios Input Offset Current ± 20 ± 200 nA SR Slew-rate Gv = 10 8 V/µs Gv = 1 (°) 6 Vo Output Voltage Swing f = 1kHz Vpp I 27 p = 0.3A 24 Ip = 3A f = 10kHz Vpp I 27 p = 0.3A 24 Ip = 3A R Input Resistance (pin 1) f = 1 KHz 100 500 KΩ Gv Voltage Gain (open loop) 80 dB eN Input Noise Voltage B = 10 to 10 000 Hz 2 µV iN Input Noise Current f = 1 KHz 100 pA CMR Common-mode Rejection Rg ≤ 10 KΩ; GV = 30 dB 70 dB SVR Supply Voltage Rejection Rg = 22 KΩ; Vripple = 0.5 Vrms fripple = 100 Hz G 60 dB v = 10 G 40 dB v = 100 Efficiency f = 1 kHz; RL = 4Ω Ip = 1.6 A; Po = 5W 70 % I 60 % p = 1.6 A; Po = 18W Tsd Thermal Shut-down Case Ptot = 12 W 110 °C Temperature Ptot = 6 W 130 °C Obsolete Product(s) - Obsolete Product(s) 3/9
