Datasheet MAX4635, MAX4636 (Maxim) - 9
ManufacturerMaxim
DescriptionFast, Low-Voltage, Dual 4Ω SPDT CMOS Analog Switches
Pages / Page11 / 9 — Fast, Low-Voltage, Dual 4. SPDT. CMOS Analog Switches. MAX4635/MAX4636. …
File Format / SizePDF / 251 Kb
Fast, Low-Voltage, Dual 4. SPDT. CMOS Analog Switches. MAX4635/MAX4636. Chip Information
Fast, Low-Voltage, Dual 4 SPDT CMOS Analog Switches MAX4635/MAX4636 Chip Information
POSITIVE SUPPLY TRANSISTOR COUNT: 239 D1 PROCESS: CMOS V+ MAX4635 MAX4636 NO_ COM_ Vg GND D2 Figure 5. Overvoltage Protection Using Two External Blocking Diodes On-resistance increases slightly at low supply voltages. Maximum supply voltage (V+) must not exceed +6V. Adding protection diode D2 causes the logic threshold to be shifted relative to GND. Protection diodes D1 and D2 also protect against some overvoltage situations. With Figure 5’s circuit, if the supply voltage is below the absolute maximum rating, and if a fault voltage up to the absolute maximum rating is applied to an analog signal pin, no damage results.
_______________________________________________________________________________________ 9
