TO-92 Tape and Reel Data, continuedTO-92 Tape and Reel Taping Dimension Configuration: Figure 4.0 HdPPdbHaW1dSLH1 HOL1WOtW2Wt1P1 F1P2DOITEM DESCRIPTIONSYMBOLDIMENSIONPO Base of Package to Lead Bend b 0.098 (max) Component Height Ha 0.928 (+/- 0.025) User Direction of Feed Lead Clinch Height HO 0.630 (+/- 0.020) Component Base Height H1 0.748 (+/- 0.020) Component Alignment ( side/side ) Pd 0.040 (max) Component Alignment ( front/back ) Hd 0.031 (max) Component Pitch P 0.500 (+/- 0.020) Feed Hole Pitch PO 0.500 (+/- 0.008) Hole Center to First Lead P1 0.150 (+0.009, -0.010) Hole Center to Component Center P2 0.247 (+/- 0.007) Lead Spread F1/F2 0.104 (+/- 0 .010) Lead Thickness d 0.018 (+0.002, -0.003) Cut Lead Length L 0.429 (max) Taped Lead Length L1 0.209 (+0.051, -0.052) Taped Lead Thickness t 0.032 (+/- 0.006) Carrier Tape Thickness t1 0.021 (+/- 0.006) Carrier Tape Width W 0.708 (+0.020, -0.019) TO-92 Reel Hold - down Tape Width WO 0.236 (+/- 0.012) Hold - down Tape position W1 0.035 (max) Configuration: Figure 5.0 Feed Hole Position W2 0.360 (+/- 0.025) Sprocket Hole Diameter DO 0.157 (+0.008, -0.007) Lead Spring Out S 0.004 (max) Note : All dimensions are in inches. ELECT ROSTATIC SEN SI TIVE D EVICES D4D1ITEM DESCRIPTIONSYSMBOLMINIMUMMAXIMUMD2 Reel Diameter D1 13.975 14.025 F63TNR Label Arbor Hole Diameter (Standard) D2 1.160 1.200 Customized Label (Small Hole) D2 0.650 0.700 Core Diameter D3 3.100 3.300 Hub Recess Inner Diameter D4 2.700 3.100 Hub Recess Depth W1 0.370 0.570 Flange to Flange Inner Width W2 1.630 1.690 W1 Hub to Hub Center Width W3 2.090 W2W3 Note: All dimensions are inches D3 July 1999, Rev. A
