Datasheet MURA115T3, MURA120T3 (ON Semiconductor)
Manufacturer | ON Semiconductor |
Description | ULTRAFAST RECTIFIERS 1 AMPERE, 100−200 VOLTS |
Pages / Page | 4 / 1 — http://onsemi.com. Features. ULTRAFAST RECTIFIERS. 1 AMPERE, 100−200 … |
File Format / Size | PDF / 96 Kb |
http://onsemi.com. Features. ULTRAFAST RECTIFIERS. 1 AMPERE, 100−200 VOLTS. Mechanical Characteristics:. SMA. CASE 403D. PLASTIC
link to page 1 link to page 1 link to page 1 MURA115T3, MURA120T3 Surface Mount Ultrafast Power Rectifiers Ideally suited for high voltage, high frequency rectification, or as free wheeling and protection diodes in surface mount applications where compact size and weight are critical to the system.
http://onsemi.com Features
• Small Compact Surface Mountable Package with J−Bend Leads •
Rectangular Package for Automated Handling •
High Temperature Glass Passivated Junction • Low Forward Voltage Drop (0.71 V Max @ 1.0 A, TJ = 150°C) • Pb−Free Packages are Available
• Case: Epoxy, Molded • Weight: 70 mg (Approximately) • Finish: All External Surfaces Corrosion Resistant and Terminal
SMA CASE 403D
Leads are Readily Solderable
PLASTIC
• Lead and Mounting Surface Temperature for Soldering Purposes: 260°C Max. for 10 Seconds • Polarity: Polarity Band Indicates Cathode Lead
MARKING DIAGRAM
• ESD Protection: Human Body Model > 4000 V (Class 3) Machine Model > 400 V (Class C U4x
MAXIMUM RATINGS
AYWW G
Rating Symbol Value Unit
Peak Repetitive Reverse Voltage VRRM V Working Peak Reverse Voltage VRWM DC Blocking Voltage MURA115T3 V U4x = Device Code R 150 MURA120T3 200 x = C for MURA115T3 = D for MURA120T3 Average Rectified Forward Current IF(AV) A A = Assembly Location @ TL = 155°C 1.0 Y = Year @ TL = 135°C 2.0 WW = Work Week Non-Repetitive Peak Surge Current IFSM 40 A G = Pb−Free Package (Surge Applied at Rated Load Conditions Halfwave, Single Phase, 60 Hz)
ORDERING INFORMATION
Operating Junction Temperature Range TJ −65 to +175 °C
Device Package Shipping
THERMAL CHARACTERISTICS
MURA115T3 SMA 5000/Tape & Reel
Characteristic Symbol Max Unit
MURA115T3G SMA 5000/Tape & Reel Thermal Resistance, Junction−to−Lead PsiJL 24 °C/W (Pb−Free) (TL = 25°C) (Note 1) (Note 2) Thermal Resistance, Junction−to−Ambient RqJA 216 MURA120T3 SMA 5000/Tape & Reel (Note 1) MURA120T3G SMA 5000/Tape & Reel Stresses exceeding Maximum Ratings may damage the device. Maximum (Pb−Free) Ratings are stress ratings only. Functional operation above the Recommended Operating Conditions is not implied. Extended exposure to stresses above the †For information on tape and reel specifications, Recommended Operating Conditions may affect device reliability. including part orientation and tape sizes, please 1. Rating applies when surface mounted on the minimum pad size recommended, refer to our Tape and Reel Packaging Specifications PC Board FR−4. Brochure, BRD8011/D. 2. In compliance with JEDEC 51, these values (historically represented by RqJL) are now referenced as PsiJL. © Semiconductor Components Industries, LLC, 2008
1
Publication Order Number:
November, 2008 − Rev. 6 MURA115T3/D
