Datasheet MURA115T3, MURA120T3 (ON Semiconductor) - 2
Manufacturer | ON Semiconductor |
Description | ULTRAFAST RECTIFIERS 1 AMPERE, 100−200 VOLTS |
Pages / Page | 4 / 2 — MURA115T3, MURA120T3. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. … |
File Format / Size | PDF / 96 Kb |
MURA115T3, MURA120T3. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Max. Unit. Figure 1. Typical Reverse Current
link to page 2 link to page 2
MURA115T3, MURA120T3 ELECTRICAL CHARACTERISTICS Characteristic Symbol Max Unit
Maximum Instantaneous Forward Voltage (Note 3) vF V (iF = 1.0 A, TJ = 25°C) 0.875 (iF = 1.0 A, TJ = 150°C) 0.71 Maximum Instantaneous Reverse Current (Note 3) iR mA (Rated DC Voltage, TJ = 25°C) 2.0 (Rated DC Voltage, TJ = 150°C) 50 Maximum Reverse Recovery Time trr 35 ns (iF = 1.0 A, di/dt = 50 A/ms) 3. Pulse Test: Pulse Width = 300 ms, Duty Cycle v 2.0%. 100 100 TJ = 175°C T mA) J = 175°C 10 mA) 10 1 TJ = 100°C TJ = 100°C 0.1 1 TJ = 25°C , REVERSE CURRENT ( TJ = 25°C , REVERSE CURRENT ( I R 0.01 I R 0.001 0.1 0 20 40 60 80 100 120 140 160 180 200 0 20 40 60 80 100 120 140 160 180 200 VR, REVERSE VOLTAGE (VOLTS) VR, REVERSE VOLTAGE (VOLTS)
Figure 1. Typical Reverse Current Figure 2. Maximum Reverse Current
10 10 100°C 100°C TC = 175°C TC = 175°C 25°C 25°C 1 1 ARD CURRENT (A) ARD CURRENT (A) W W 0.1 0.1 ANEOUS FOR ANEOUS FOR ANT ANT 0.01 0.01 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 , INST 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 , INST I F I F VF, INSTANTANEOUS VOLTAGE (VOLTS) VF, INSTANTANEOUS VOLTAGE (VOLTS)
Figure 3. Typical Forward Voltage Figure 4. Maximum Forward Voltage http://onsemi.com 2
