Datasheet RAA227063 (Renesas) - 5
Manufacturer | Renesas |
Description | 4.5V to 60V 3-Phase Smart Gate Driver |
Pages / Page | 74 / 5 — RAA2. VIN = 4.5V to 60V. 270. Dat. IDG. h ee. VCP. osc. MCU. 500mA … |
File Format / Size | PDF / 2.8 Mb |
RAA2. VIN = 4.5V to 60V. 270. Dat. IDG. h ee. VCP. osc. MCU. 500mA Buck-boost. 1/2. w/ V. COMP. IN UVLO, VOUT OV/. Charge Pump w/. UV, OCP. VCP UVLO. GHA
Nov 29, 20 R16
RAA2
D
VIN = 4.5V to 60V
S0
270
045 21
63
EU0
E Dat
1
1 2 RV L IDG H
0
ND R a
1
FB VM SW SW CP CP s PG VD VB h ee
Rev
VCP osc t MCU 500mA Buck-boost
1/2
1.01
w/ V COMP IN UVLO, VOUT OV/ Charge Pump w/ UV, OCP VCP UVLO GHA HS Level SHA VDD AUXVCC Shifter MCU FBLDO LDO2 LDO3 GLA LS GND VCC LDO1 SPA SGND
EN GPIO GHB HS
l a
HIA Level SHB Shifter
H
LIA HIB Core Logic DPWM (or GLB LIB Smart Gate Drive LS GPIO) Protection HIC LIC SPB Control Inputs IDRV/SDI & Configuration Interface AUXVCC GHC HS SPI Master MODE/SDO Level SHC CSGAIN/SCLK VBRIDGE Shifter SHA VDSTH/nSCS SPA GLC VCC VDS Shoot- LS SHB through/OCP SPB AUXVCC DT/IFSEL/BEN Protection SHC SPC SPC SPA nFault Fault Output GPIO SNA CSOA SPB A/D
Amplifier stages support flexible configuration to: CSOB/SNS_SEL2 1) Up to 3-phase current sensing (Shunt or rDS(ON)) SNB/BEPHSEL2 A/D 2) Up to 2-phase current sensing + BEMF sensing CSOC/BEMFO/SNS_SEL1
Internal S/H of sensed signal can be enabled for shunt sense and SPC A/D BEMF sense VREF
See the Current Sensing and BEMF Sensing section SNC/BEPHSEL1 VREF VBRIDGE VCC SHA POR VBRIDGEUVLO SHB COMMON SHC
Page
EPAD
5
Figure 3. RAA227063 Simplified Diagram and Application – SPI Interface Operation, BEMF Sensing Disabled, No S/H for Current Sense
Document Outline Applications Features Contents 1. Overview 1.1 Typical Application Circuits 2. Pin Information 2.1 Pin Assignments 2.2 Pin Descriptions 3. Specifications 3.1 Absolute Maximum Ratings 3.2 Thermal Information 3.3 Recommended Operating Conditions 3.4 Electrical Specifications 4. Typical Performance Curves 5. Functional Description 5.1 Modes of Operation and Power-On Sequence 5.1.1 Definitions of State of Different Modes 5.1.2 Mode Transition 5.1.3 Modes of Operation 5.1.3.1 Gate Driver Control Modes 5.1.3.2 3-phase HI/LI Mode 5.1.3.3 3-phase PWM Mode 5.1.4 Gate Driver Structure and Feature 5.1.4.1 Driver Structure 5.1.4.2 Adjustable Slew-Rate 5.1.4.3 Driver Robustness Enhancement 5.1.4.4 Gate Drive Diagram 5.1.4.5 Gate Drive Scheme in 3-phase HI/LI Mode 5.1.5 Power Architecture 5.1.5.1 Power Architecture Overview 5.1.5.2 Low-Side Driver Supply (VDRV) 5.1.5.3 Charge Pump 5.1.5.4 VCC Supply 5.1.5.5 MCU AUXVCC Supply 5.1.6 Power-On Sequence 5.2 Fault Management 5.2.1 Fault Conditions Types 5.2.2 nFAULT Indicator 5.3 Current Sensing and BEMF Sensing 5.3.1 Overview 5.3.2 Details on Different Sensing Configurations 5.3.2.1 Configuration 1 5.3.2.2 Configuration 2 5.3.2.3 Configuration 3 5.3.2.4 Configuration 4 5.3.2.5 Configuration 5 5.3.2.6 Configuration 6 5.3.2.7 Configuration 7 5.3.2.8 Configuration 8 5.3.2.9 Configuration 9 5.3.3 Structure of Amplifiers CSA, CSB, and CSC 5.3.4 BEMF Sensing Control Signal Logic 5.3.5 Multiplexer Control Signal Logic 5.3.6 Sample and Hold Timing Logic 5.3.7 Low-Side rDS(ON) Current Sensing Timing Logic 5.4 Hardware Interface for Parameter Setting 5.4.1 Parameter Setting Tables 5.5 Serial Peripheral Interface (SPI) 5.5.1 Communication Protocol 5.5.2 Timing Diagram 6. Register Map 7. Package Outline Drawing 8. Ordering Information 9. Revision History
