Datasheet MAX6126 (Analog Devices) - 3
DescriptionUltra-High-Precision, Ultra-Low-Noise, Series Voltage Reference
Pages / Page28 / 3 — Electrical Characteristics—MAX6126_21 (VOUT = 2.048V) (continued). …
File Format / SizePDF / 4.0 Mb
Electrical Characteristics—MAX6126_21 (VOUT = 2.048V) (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Electrical Characteristics—MAX6126_21 (VOUT = 2.048V) (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6126 Ultra-High-Precision, Ultra-Low-Noise, Series Voltage Reference
(VIN = 5V, CLOAD = 0.1μF, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS DYNAMIC CHARACTERISTICS
f = 0.1Hz to 10Hz 1.3 µVP-P Noise Voltage eOUT f = 1kHz, CNR = 0 60 nV/√Hz f = 1kHz, CNR = 0.1µF 35 C Turn-On Settling Time t To VOUT = 0.01% of NR = 0 0.8 R final value ms CNR = 0.1µF 20 Capacitive-Load Stability Range CLOAD No sustained oscillations 0.1 to 10 µF
INPUT
Supply Voltage Range VIN Guaranteed by line-regulation test 2.7 12.6 V T Quiescent Supply Current I A = +25°C 380 550 IN µA TA = -40°C to +125°C 725
Electrical Characteristics—MAX6126_25 (VOUT = 2.500V)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
Output Voltage VOUT TA = +25°C 2.500 V A grade SO -0.02 +0.02 B grade SO -0.06 +0.06 Output Voltage Accuracy Referred to VOUT, T % A = +25°C A grade µMAX -0.06 +0.06 B grade µMAX -0.1 +0.1 A grade SO 0.5 3 TA = -40°C to B grade SO 1 5 +85°C A grade µMAX 1 3 Output Voltage Temperature B grade µMAX 2 7 Coefficient (Note 1) TCVOUT ppm/°C A grade SO 1 5 TA = -40°C to B grade SO 2 10 +125°C A grade µMAX 2 5 B grade µMAX 3 12 T Line Regulation ΔVOUT/ A = +25°C 3 20 ΔV 2.7V ≤ VIN ≤ 12.6V µV/V IN TA = -40°C to +125°C 40 Sourcing: 0 ≤ I Load Regulation ΔVOUT/ OUT ≤ 10mA 1 25 ΔI µV/mA OUT Sinking: -10mA ≤ IOUT ≤ 0 1.8 25 www.maximintegrated.com Maxim Integrated │ 3
