Datasheet FDV303N (ON Semiconductor) - 3
ManufacturerON Semiconductor
DescriptionDigital FET, N-Channel
Pages / Page7 / 3 — FDV303N. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Conditions. Min. …
Revision5
File Format / SizePDF / 270 Kb
FDV303N. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Conditions. Min. Typ. Max. Units. OFF CHARACTERISTICS. ON CHARACTERISTICS
FDV303N ELECTRICAL CHARACTERISTICS Symbol Parameter Conditions Min Typ Max Units OFF CHARACTERISTICS ON CHARACTERISTICS
link to page 3 link to page 3 link to page 3
TJ = 25°C unless otherwise noted
BVDSS Drain−Source Breakdown Voltage VGS = 0 V, ID = 250 mA 25 V ΔBVDSS/ Breakdown Voltage Temp. Coefficient ID = 250 mA, Referenced to 25°C 26 mV/°C ΔTJ IDSS Zero Gate Voltage Drain Current VDS = 20 V, VGS = 0 V 1 mA TJ = 55°C 10 mA IGSS Gate − Body Leakage Current VGS = 8 V, VDS= 0 V 100 nA
ON CHARACTERISTICS
(Note 1) ΔVGS(th)/ Gate Threshold Voltage Temperature ID = 250 mA, Referenced to 25°C −2.6 mV/°C ΔTJ Coefficient VGS(th) Gate Threshold Voltage VDS = VGS, ID = 250 mA 0.65 0.8 1 V RDS(ON) Static Drain−Source On−Resistance VGS = 4.5 V, ID = 0.5 A 0.33 0.45 Ω T
J
=125°C 0.52 0.8 VGS = 2.7 V, ID = 0.2 A 0.44 0.6 ID(ON) On−State Drain Current VGS = 2.7 V, VDS = 5 V 0.5 A gFS Forward Transconductance VDS = 5 V, ID= 0.5 A 1.45 S
DYNAMIC CHARACTERISTICS
Ciss Input Capacitance VDS = 10 V, VGS = 0 V, f = 1.0 MHz 50 pF Coss Output Capacitance 28 pF Crss Reverse Transfer Capacitance 9 pF
SWITCHING CHARACTERISTICS
(Note 1) tD(on) Turn − On Delay Time VDD = 6 V, ID = 0.5 A, VGS = 4.5 V, RGEN = 50 Ω 3 6 ns tr Turn − On Rise Time 8.5 18 ns tD(off) Turn − Off Delay Time 17 30 ns tf Turn − Off Fall Time 13 25 ns Qg Total Gate Charge VDS = 5 V, ID = 0.5 A, VGS = 4.5 V 1.64 2.3 nC Qgs Gate−Source Charge 0.38 nC Qgd Gate−Drain Charge 0.45 nC
DRAIN−SOURCE DIODE CHARACTERISTICS AND MAXIMUM RATINGS
IS Maximum Continuous Drain−Source Diode Forward Current 0.3 A VSD Drain−Source Diode Forward Voltage VGS = 0 V, IS = 0.5 A (Note 1) 0.83 1.2 V 1. Pulse Test: Pulse Width < 300 ms, Duty Cycle < 2.0%.
www.onsemi.com 3
