Datasheet MAX4040, MAX4041, MAX4042, MAX4043, MAX4044 (Maxim) - 7
Manufacturer | Maxim |
Description | Single/Dual/Quad, Low-Cost, SOT23, Micropower Rail-to-Rail I/O Op Amps |
Pages / Page | 16 / 7 — Single/Dual/Quad, Low-Cost, SOT23,. Micropower, Rail-to-Rail I/O Op Amps. … |
File Format / Size | PDF / 388 Kb |
Single/Dual/Quad, Low-Cost, SOT23,. Micropower, Rail-to-Rail I/O Op Amps. MAX4040–MAX4044
Single/Dual/Quad, Low-Cost, SOT23, Micropower, Rail-to-Rail I/O Op Amps MAX4040–MAX4044 ____________________________________Typical Operating Characteristics (continued)
(VCC = +5.0V, VEE = 0, VCM = VCC / 2, SHDN = VCC, RL = 100kΩ to VCC / 2, TA = +25°C, unless otherwise noted.)
MAX4042/MAX4043/MAX4044 TOTAL HARMONIC DISTORTION PLUS NOISE CROSSTALK vs. FREQUENCY vs. FREQUENCY
-60 1 RL = 10kΩ MAX4040/44-18 -70 MAX4040/44-19 -80 0.1 GAIN (dB) -90 THD + NOISE (%) -100 RL = 100kΩ RL = 10kΩ -110 0.01 10 100 1k 10k 1 10 100 1000 FREQUENCY (Hz) FREQUENCY (Hz)
LOAD RESISTOR vs. SMALL-SIGNAL TRANSIENT RESPONSE CAPACITIVE LOAD (NONINVERTING)
MAX4040/44-21 1000 10% OVERSHOOT 100mV MAX4040/44-20 REGION OF IN ) MARGINAL STABILITY 0V Ω (k 100 50mV/div R LOAD 100mV REGION OF OUT STABLE OPERATION 0V 10 0 250 500 750 1000 10µs/div CLOAD (pF)
SMALL-SIGNAL TRANSIENT RESPONSE LARGE-SIGNAL TRANSIENT RESPONSE LARGE-SIGNAL TRANSIENT RESPONSE (INVERTING) (NONINVERTING) (INVERTING)
MAX4040/44-22 MAX4040/42/44-23 MAX4040/42/44-24 4.5V 100mV +2V IN IN IN 0.5V 0V -2V 50mV/div 2V/div 2V/div 4.5V 100mV +2V OUT OUT OUT 0.5V 0V -2V 10µs/div 100µs/div 100µs/div
_______________________________________________________________________________________ 7
