Datasheet MAX4040, MAX4041, MAX4042, MAX4043, MAX4044 (Maxim) - 6
Manufacturer | Maxim |
Description | Single/Dual/Quad, Low-Cost, SOT23, Micropower Rail-to-Rail I/O Op Amps |
Pages / Page | 16 / 6 — Single/Dual/Quad, Low-Cost, SOT23, Micropower, Rail-to-Rail I/O Op Amps |
File Format / Size | PDF / 388 Kb |
Single/Dual/Quad, Low-Cost, SOT23, Micropower, Rail-to-Rail I/O Op Amps ____________________________________Typical Operating Characteristics (continued)
(VCC = +5.0V, VEE = 0, VCM = VCC / 2, SHDN = VCC, RL = 100kΩ to VCC / 2, TA = +25°C, unless otherwise noted.)
OPEN-LOOP GAIN vs. OUTPUT SWING LOW OPEN-LOOP GAIN vs. OUTPUT SWING HIGH OPEN-LOOP GAIN vs. OUTPUT SWING LOW (VCC = +2.4V, RL TIED TO VCC) (VCC = +2.4V, RL TIED TO VEE) (VCC = +5.5V, RL TIED TO VCC)
100 100 110 R 90 90 L = 100kΩ 100 R MAX4040/44-10 R L = 100kΩ L = 100kΩ MAX4040/44-11 MAX4040/44-12 80 80 90 RL = 10kΩ RL = 20kΩ RL = 10kΩ 70 70 80 GAIN (dB) 60 GAIN (dB) 60 GAIN (dB) 70 50 50 60 40 40 50 30 30 40 0 100 200 300 400 500 0 100 200 300 400 500 0 100 200 300 400
MAX4040–MAX4044
∆VOUT (mV) ∆VOUT (mV) ∆VOUT (mV)
OPEN-LOOP GAIN vs. OUTPUT SWING HIGH OPEN-LOOP GAIN OPEN-LOOP GAIN (VCC = +5.5V, RL TIED TO VEE) vs. TEMPERATURE vs. TEMPERATURE
110 110 110 RL = 100kΩ 100 105 105 MAX4040/44-13 MAX4040/44-14 V V MAX4040/44-15 CC = +5.5V, RL TO VEE CC = +5.5V, RL = 20kΩ TO VEE 100 100 90 95 95 VCC = +5.5V, RL TO VCC 80 RL = 20kΩ 90 V 90 CC = +5.5V, RL = 20kΩ TO VCC VCC = +2.4V, RL TO VEE GAIN (dB) 70 GAIN (dB) GAIN (dB) 85 85 VCC = +2.4V, RL TO VCC 60 VCC = +2.4V, RL = 10kΩ TO VEE 80 80 50 75 75 VCC = +2.4V, RL = 10kΩ TO VCC 40 70 70 0 100 200 300 400 -60 -40 -20 0 20 40 60 80 100 -60 -40 -20 0 20 40 60 80 100 ∆VOUT (mV) TEMPERATURE (°C) TEMPERATURE (°C)
GAIN AND PHASE vs. FREQUENCY GAIN AND PHASE vs. FREQUENCY (NO LOAD) (CL = 100pF)
MAX4040/44-16 60 180 MAX4040/44-17 60 180 AV = +1000V/V A 50 144 50 V = +1000V/V 144 40 108 40 108 30 72 30 72 20 36 20 36 10 0 10 0 GAIN (dB) GAIN (dB) 0 -36 0 -36 PHASE (DEGREES) PHASE (DEGREES) -10 -72 -10 -72 -20 -108 -20 -108 -30 -144 -30 -144 -40 -180 -40 -180 10 100 1k 10k 100k 10 100 1k 10k 100k FREQUENCY (Hz) FREQUENCY (Hz)
6 _______________________________________________________________________________________
