Datasheet MAX4040, MAX4041, MAX4042, MAX4043, MAX4044 (Maxim) - 5
Manufacturer | Maxim |
Description | Single/Dual/Quad, Low-Cost, SOT23, Micropower Rail-to-Rail I/O Op Amps |
Pages / Page | 16 / 5 — Single/Dual/Quad, Low-Cost, SOT23,. Micropower, Rail-to-Rail I/O Op Amps. … |
File Format / Size | PDF / 388 Kb |
Single/Dual/Quad, Low-Cost, SOT23,. Micropower, Rail-to-Rail I/O Op Amps. MAX4040–MAX4044
Single/Dual/Quad, Low-Cost, SOT23, Micropower, Rail-to-Rail I/O Op Amps MAX4040–MAX4044 Typical Operating Characteristics (continued)
(VCC = +5.0V, VEE = 0, VCM = VCC / 2, SHDN = VCC, RL = 100kΩ to VCC / 2, TA = +25°C, unless otherwise noted.)
INPUT OFFSET VOLTAGE INPUT BIAS CURRENT INPUT BIAS CURRENT vs. vs. TEMPERATURE vs. TEMPERATURE COMMON-MODE VOLTAGE (VCC = 2.4V)
400 0 5.0 V V CC = +2.4V CM = 0 V MAX4040/44-03 CC = +2.4V MAX4040/44-5 MAX4040/44-04 µV) 300 -1 2.5 VCC = +5.5V (nA) 200 -2 0 I BIAS 100 INPUT BIAS CURRENT (nA) -3 -2.5 INPUT OFFSET VOLTAGE ( 0 -4 -5.0 -60 -40 -20 0 20 40 60 80 100 -60 -40 -20 0 20 40 60 80 100 0 0.2 0.6 1.0 1.4 1.8 2.2 TEMPERATURE (°C) TEMPERATURE (°C) VCM (V)
INPUT BIAS CURRENT vs. OUTPUT SWING HIGH COMMON-MODE VOLTAGE (VCC = 5.5V) vs. TEMPERATURE
5.0 120 VCC = +5.5V RL TO VEE 100 MAX4040/44-06 MAX4040/44-07 2.5 (mV) 80 VCC = +2.4V, RL = 10kΩ CC (nA) 0 60 VCC = +5.5V, RL = 20kΩ I BIAS 40 VOLTAGE FROM V -2.5 VCC = +5.5V, RL = 100kΩ 20 VCC = +2.4V, RL = 100kΩ -5.0 0 0 0.5 1.5 2.5 3.5 4.5 5.5 -60 -40 -20 0 20 40 60 80 100 VCM (V) TEMPERATURE (°C)
OUTPUT SWING LOW COMMON-MODE REJECTION vs. TEMPERATURE vs. TEMPERATURE
120 -80 RL TO VCC 100 MAX4040/44-08 MAX4040/44-09 -85 (mV) 80 EE V 60 -90 CC = +2.4V VCC = +5.5V, RL = 20kΩ 40 VOLTAGE FROM V V V CC = +2.4V, RL = 10kΩ -95 CC = +5.5V COMMON-MODE REJECTION (dB) 20 VCC = +5.5V, RL = 100kΩ VCC = +2.4V, RL = 100kΩ 0 -100 -60 -40 -20 0 20 40 60 80 100 -60 -40 -20 0 20 40 60 80 100 TEMPERATURE (°C) TEMPERATURE (°C)
_______________________________________________________________________________________ 5
