Datasheet FDD6637 (Fairchild) - 7
ManufacturerFairchild
Description35V P-Channel PowerTrench MOSFET
Pages / Page7 / 7 — TRADEMARKS. DISCLAIMER. LIFE SUPPORT POLICY. PRODUCT STATUS DEFINITIONS. …
File Format / SizePDF / 126 Kb
TRADEMARKS. DISCLAIMER. LIFE SUPPORT POLICY. PRODUCT STATUS DEFINITIONS. Definition of Terms. Datasheet Identification
TRADEMARKS DISCLAIMER LIFE SUPPORT POLICY PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification
TRADEMARKS
The following are registered and unregistered trademarks Fairchild Semiconductor owns or is authorized to use and is not intended to be an exhaustive list of all such trademarks. ACEx™ FAST® ISOPLANAR™ PowerSaver™ SuperSOT™-6 ActiveArray™ FASTr™ LittleFET™ PowerTrench® SuperSOT™-8 FPS™ Bottomless™ MICROCOUPLER™ QFET® SyncFET™ Build it Now™ FRFET™ MicroFET™ QS™ TinyLogic® CoolFET™ GlobalOptoisolator™ MicroPak™ QT Optoelectronics™ TINYOPTO™ CROSSVOLT™ GTO™ MICROWIRE™ Quiet Series™ TruTranslation™ DOME™ HiSeC™ MSX™ RapidConfigure™ UHC™ EcoSPARK™ I2C™ MSXPro™ RapidConnect™ UltraFET® E2CMOS™ i-Lo™ OCX™ μSerDes™ UniFET™ EnSigna™ OCXPro™ ImpliedDisconnect™ ScalarPump™ VCX™ FACT™ OPTOLOGIC® IntelliMAX™ SILENT SWITCHER® Wire™ OPTOPLANAR™ FACT Quiet Series™ SMART START™ PACMAN™ SPM™ Across the board. Around the world.™ POP™ Stealth™ The Power Franchise® Power247™ SuperFET™ Programmable Active Droop™ PowerEdge™ SuperSOT™-3
DISCLAIMER
FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or 2. A critical component is any component of a life systems which, (a) are intended for surgical implant into support device or system whose failure to perform can the body, or (b) support or sustain life, or (c) whose be reasonably expected to cause the failure of the life failure to perform when properly used in accordance support device or system, or to affect its safety or with instructions for use provided in the labeling, can be effectiveness. reasonably expected to result in significant injury to the user.
PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Definition
Advance Information Formative or This datasheet contains the design specifications for In Design product development. Specifications may change in any manner without notice. Preliminary First Production This datasheet contains preliminary data, and supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice in order to improve design. No Identification Needed Full Production This datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice in order to improve design. Obsolete Not In Production This datasheet contains specifications on a product that has been discontinued by Fairchild semiconductor. The datasheet is printed for reference information only. Rev. I17
