Datasheet TLP624, TLP624-2, TLP624-4 (Toshiba) - 3
Manufacturer | Toshiba |
Description | TOSHIBA Photocoupler IRED & Photo-Transistor |
Pages / Page | 9 / 3 — Absolute Maximum Ratings (Ta = 25°C). Recommended Operating Conditions |
File Format / Size | PDF / 370 Kb |
TLP624,TLP624-2,TLP624-4
Rating Characteristic Symbol Unit TLP624 TLP624-2 TLP624-4 Forward current IF 60 50 mA Forward current detating ΔIF / °C -0.7(Ta ≥ 39°C) -0.5(Ta ≥ 25°C) mA / °C Pulse forward current IFP 1 (100μs, pulse, 100pps) A D LE Diode Power dissipation PD 100 70 mW Diode Power dissipation derating ΔPD / °C -1.2(Ta ≥ 39°C) -0.7(Ta ≥ 25°C) mW / °C Reverse voltage VR 5 V Junction temperature Tj 125 °C Collector-emitter voltage VCEO 55 V Emitter-collector voltage VECO 7 V tor Collector current IC 50 mA ec et D Collector power dissipation (1 circuit) PC 150 100 mW Collector power dissipation derating (Ta ≥ 25°C, 1 circuit) ΔPC / °C -1.5 -1.0 mW / °C Junction temperature Tj 125 °C Storage temperature range Tstg -55 to 125 °C Operating temperature range Popr -55 to 100 °C Lead soldering temperature Tsol 260 (10 s) °C Total package power dissipation (1 circuit) PT 250 150 mW Total package power dissipation derating (Ta ≥ 25°C, 1 circuit) ΔPT / °C -2.5 -1.5 mW / °C Isolation voltage (Note 1) BVS 5000 (AC, 60 s, R.H.≤60 %) Vrms Note: Using continuously under heavy loads (e.g. the application of high temperature/current/voltage and the significant change in temperature, etc.) may cause this product to decrease in the reliability significantly even if the operating conditions (i.e. operating temperature/current/voltage, etc.) are within the absolute maximum ratings. Please design the appropriate reliability upon reviewing the Toshiba Semiconductor Reliability Handbook (“Handling Precautions”/“Derating Concept and Methods”) and individual reliability data (i.e. reliability test report and estimated failure rate, etc). Note 1: Device considered a two terminal device: LED side pins shorted together, and detector side pins shorted together.
Characteristic Symbol Min Typ. Max Unit Supply voltage VCC ― 5 24 V Forward current IF ― 1.6 20 mA Collector current IC ― 1 10 mA Operating temperature Topr -25 ― 75 °C Note: Recommended operating conditions are given as a design guideline to obtain expected performance of the device. Additionally, each item is an independent guideline respectively. In developing designs using this product, please confirm specified characteristics shown in this document. © 2019 3 2019-06-24 Toshiba Electronic Devices & Storage Corporation
