Datasheet CMHZ4678 - CMHZ4717 (Central Semiconductor)
Manufacturer | Central Semiconductor |
Description | SURFACE MOUNT SILICON LOW LEVEL ZENER DIODES 500mW, 1.8 - 43 VOLT 5% TOLERANCE |
Pages / Page | 6 / 1 — CMHZ4678 THRU CMHZ4717. SURFACE MOUNT SILICON. w w w. c e n t r a l s e m … |
File Format / Size | PDF / 786 Kb |
CMHZ4678 THRU CMHZ4717. SURFACE MOUNT SILICON. w w w. c e n t r a l s e m i . c o m. LOW LEVEL ZENER DIODES. DESCRIPTION:
CMHZ4678 THRU CMHZ4717 SURFACE MOUNT SILICON w w w. c e n t r a l s e m i . c o m LOW LEVEL ZENER DIODES DESCRIPTION: 500mW, 1.8 THRU 43 VOLT
The CENTRAL SEMICONDUCTOR CMHZ4678 series
5% TOLERANCE
low level silicon Zener diode is a highly reliable voltage regulator designed for applications requiring an extremely low operating current and low leakage.
MARKING CODE: SEE MARKING CODE ON ELECTRICAL CHARACTERISTIC TABLE SOD-123 CASE MAXIMUM RATINGS:
(TL=75°C)
SYMBOL UNIT
Power Dissipation PD 500 mW Operating and Storage Junction Temperature TJ, Tstg -65 to +150 °C
ELECTRICAL CHARACTERISTICS:
(TA=25°C), VF=1.5V MAX @ IF=100mA (for all types)
TEST MAXIMUM MAXIMUM MAXIMUM ZENER VOLTAGE CURRENT REVERSE ZENER NOISE MARKING TYPE CURRENT CURRENT DENSITY CODE VZ @ IZT IZT IR @ VR IZM ND @ IZT MIN NOM MAX μA μA V mA μV/ Hz V V V
CMHZ4678 1.710 1.8 1.890 50 7.5 1.0 120.0 1.0 CCC CMHZ4679 1.900 2.0 2.100 50 5.0 1.0 110.0 1.0 CCD CMHZ4680 2.090 2.2 2.310 50 4.0 1.0 100.0 1.0 CCE CMHZ4681 2.280 2.4 2.520 50 2.0 1.0 95.0 1.0 CCF CMHZ4682 2.565 2.7 2.835 50 1.0 1.0 90.0 1.0 CCH CMHZ4683 2.850 3.0 3.150 50 0.8 1.0 85.0 1.0 CCJ CMHZ4684 3.135 3.3 3.465 50 7.5 1.5 80.0 1.0 CCK CMHZ4685 3.420 3.6 3.780 50 7.5 2.0 75.0 1.0 CCM CMHZ4686 3.705 3.9 4.095 50 5.0 2.0 70.0 1.0 CCN CMHZ4687 4.085 4.3 4.515 50 4.0 2.0 65.0 1.0 CCP CMHZ4688 4.465 4.7 4.935 50 10 3.0 60.0 1.0 CCT CMHZ4689 4.845 5.1 5.355 50 10 3.0 55.0 2.0 CCU CMHZ4690 5.320 5.6 5.880 50 10 4.0 50.0 4.0 CCV CMHZ4691 5.890 6.2 6.510 50 10 5.0 45.0 5.0 CCA CMHZ4692 6.460 6.8 7.140 50 10 5.1 35.0 40 CCX CMHZ4693 7.125 7.5 7.875 50 10 5.7 31.8 40 CCY CMHZ4694 7.790 8.2 8.610 50 1.0 6.2 29.0 40 CCZ CMHZ4695 8.265 8.7 9.135 50 1.0 6.6 27.4 40 CDC CMHZ4696 8.645 9.1 9.555 50 1.0 6.9 26.2 40 CDD R7 (23-September 2015)
