Datasheet CMPZ5235B - CMPZ5261B (Central Semiconductor) - 9
Manufacturer | Central Semiconductor |
Description | 0.5 Watt Zener Diode Chip |
Pages / Page | 10 / 9 — http://www.centralsemi.com. * All Plating types (PBFREE,TIN/LEAD) for … |
File Format / Size | PDF / 744 Kb |
http://www.centralsemi.com. * All Plating types (PBFREE,TIN/LEAD) for each item listed are included in this notice
PDN00999 8/03/15 Varies
Varies *** CONTINUED FROM PRIOR PAGE ***
* All Plating types (PBFREE,TIN/LEAD) for each item listed are included in this notice. Central Part Number Replacement
CP517-TIP126-CT CP630-TIP127-CT CP517-2N6042-CT CP527-2N6042-CT CP517-2N6053-CM CP527-2N6053-CM CP517-2N6053-CT CP527-2N6053-CT CP517-2N6296-CT CP527-2N6296-CT CP517-2N6299-CT CP527-2N6299-CT CP517-2N6299-WS CP527-2N6299-WR CP517-2N6668-CT CP527-2N6668-CT CP529-CMPT2907A-WN N/A, Stock Only CP548-2N5116-WN N/A, Stock Only CP555-2N4209-WN CP742X-CM4209-WN CP559-2N2907A-WN N/A, Stock Only CP560-MPSA92-CT CP710V-MPSA92-CT CP560-MPSA92-WN CP710V-MPSA92-WN CP560-2N6520-WN CP710V-2N6520-WN CP584-2N5401-CTAN N/A, Stock Only CP584-2N5401-WN N/A, Stock Only CP587-2N3964-WN N/A, Stock Only CP588-BCW70-CT CP788X-BCW70-CT CP588-2N3799-WN CP788X-2N3799-CT CP588-2N5087-CT N/A, Stock Only CP588V-BC556B-WR N/A, Stock Only CP588V-2N2605-CT CP788X-2N2605-CT CP588V-2N3799-WN N/A, Stock Only CP588V-2N5087-CT CP788X-2N5087-CT CP591-2N2907A-CT CP591X-2N2907A-CT CP591V-2N2907A-CT CP591X-2N2907A-CT CP592-CMPT3906-CT CP792V-CMPT3906-CT CP592-2N3251-CT CP792V-2N3251-CT CP592-2N3906-WN CP792V-2N3906-WN CP701-2N5416-CT CP710V-2N5416-CT CP705-BC327-25-CT N/A, Stock Only CP705-BC327-40-CT N/A, Stock Only CP705-BC807-40-CT N/A, Stock Only CP705-BD140-CT N/A, Stock Only CP705-CZT4033-CT CP705V-CZT4033-CT CP705-D41D11-CT CP705V-D41D11-CT CP705-D41D11-CT200 CP705V-D41D11-CT200 CP705-2N4356-CT N/A, Stock Only CP705-2N4356-WN N/A, Stock Only CP707-MPSA64-WN CP727V-MPSA64-WN CP707-MPSU95-CT CP727V-MPSU95-CT CP710-CMPTA94-CT CP710V-CMPTA94-CT *** CONTINUED ***
