Datasheet ADG333A (Analog Devices)
Description | Quad SPDT Switch |
Pages / Page | 13 / 1 — Quad SPDT Switch. Data Sheet. ADG333A. FEATURES. FUNCTIONAL BLOCK … |
Revision | B |
File Format / Size | PDF / 246 Kb |
Quad SPDT Switch. Data Sheet. ADG333A. FEATURES. FUNCTIONAL BLOCK DIAGRAM. 44 V supply maximum ratings. S1A. S4A
Quad SPDT Switch Data Sheet ADG333A FEATURES FUNCTIONAL BLOCK DIAGRAM 44 V supply maximum ratings S1A S4A VSS to VDD analog signal range D1 D4 Low on resistance (45 Ω max) S1B S4B Low ∆RON (5 Ω max) IN1 IN4 Low RON match (4 Ω max) ADG333A Low power dissipation IN2 IN3 Fast switching times t S2B S3B ON < 175 ns D2 D3 tOFF < 145 ns S2A S3A Low leakage currents (5 nA max)
01 0 2-
Low charge injection (10 pC max) SWITCHES SHOWN FOR A LOGIC 1 INPUT
121 0
Break-before-make switching action
Figure 1.
APPLICATIONS Audio and video switching Battery-powered systems Test equipment Communication systems GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG333A is a monolithic complementary metal-oxide 1. Extended signal range. The ADG333A is fabricated on an semiconductor (CMOS) device comprising four independently enhanced LC2MOS process, giving an increased signal selectable single-pole, double-throw (SPDT) switches. It is range which extends to the supply rails. designed on a linear compatible CMOS (LC2MOS) process, 2. Low power dissipation. which provides low power dissipation yet achieves a high 3. Low RON. switching speed and a low on resistance. 4. Single-supply operation. For applications in which the analog signal is unipolar, the ADG333A can be operated The on-resistance profile is very flat over the full analog input from a single rail power supply. The device is fully range, ensuring good linearity and low distortion when switching specified with a single 12 V supply. audio signals. High switching speed also makes the device suitable for video signal switching. CMOS construction ensures ultralow power dissipation, making the device ideally suited for portable, battery-powered instruments. When they are on, each switch conducts equally well in both directions and has an input signal range that extends to the power supplies. In the off condition, signal levels up to the supplies are blocked. All switches exhibit break-before-make switching action for use in multiplexer applications. Low charge inject is inherent in the design.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©1995–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION TERMINOLOGY PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS APPLICATIONS INFORMATION ADG333A SUPPLY VOLTAGES POWER SUPPLY SEQUENCING OUTLINE DIMENSIONS ORDERING GUIDE
