Datasheet ADG1519 (Analog Devices) - 7
Description3.8 Ω On-Resistance, SPDT Switch
Pages / Page15 / 7 — ADG1519. TYPICAL PERFORMANCE CHARACTERISTICS. Figure 3. On Resistance as …
File Format / SizePDF / 673 Kb
ADG1519. TYPICAL PERFORMANCE CHARACTERISTICS. Figure 3. On Resistance as a Function of VS and VD
ADG1519 TYPICAL PERFORMANCE CHARACTERISTICS Figure 3 On Resistance as a Function of VS and VD
Data Sheet
ADG1519 TYPICAL PERFORMANCE CHARACTERISTICS Figure 3. On Resistance as a Function of VS and VD Figure 6. On Leakage as a Function of Temperature Figure 4. On Resistance as a Function of VS and VD for Different Figure 7. IDD vs. Logic Level, IN Temperatures Figure 8. Charge Injection vs. VS Figure 5. Off Leakage as a Function of Temperature analog.com Rev. 0 | 7 of 15
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Specifications Dual Supply Continuous Current Per Channel, Sx or D Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology IDD ISS VD and VS RON RFLAT ON IS Off ID Off ID and IS On VINL VINH IINL and IINH CS Off CD Off CD and CS On CIN tON EN tOFF EN tTRANSITION TD Charge Injection Off Isolation Crosstalk Bandwidth Insertion Loss THD + N THD AC PSRR Applications Information Power Amplifier Gate Drive Power Supply Rails Power Supply Recommendations Outline Dimensions Ordering Guide Evaluation Boards
