Datasheet ADG1519 (Analog Devices)
Description3.8 Ω On-Resistance, SPDT Switch
Pages / Page15 / 1 — ADG1519. FEATURES. FUNCTIONAL BLOCK DIAGRAM. APPLICATIONS. Figure 1. …
File Format / SizePDF / 673 Kb
ADG1519. FEATURES. FUNCTIONAL BLOCK DIAGRAM. APPLICATIONS. Figure 1. PRODUCT HIGHLIGHTS. GENERAL DESCRIPTION. Rev. 0. DOCUMENT FEEDBACK
Datasheet ADG1519 Analog Devices
link to page 15 Data Sheet
ADG1519
FEATURES FUNCTIONAL BLOCK DIAGRAM
► 3.8 Ω on resistance ► Specified at ► VDD = +5 V ± 10% ► VSS = –4.5 V to –8.8 V ► No VL supply required ► 3 V logic-compatible inputs ► Up to 310 mA continuous current ► Rail-to-rail operation ► 8-lead, 2 mm × 3 mm LFCSP
► LDMOS power amplifier gate drive
Figure 1.
► GAN power amplifier gate drive
PRODUCT HIGHLIGHTS
► Communication systems ► Automatic test equipment
1.
5.2 Ω maximum on resistance at 25°C. ► Data acquisition systems
2.
–135 dB THD. ► Sample-and-hold systems
3.
3 V logic-compatible digital inputs: VINH = 2.0 V minimum and V
GENERAL DESCRIPTION
INL = 0.8 V maximum.
4.
No logic power supply voltage (VL) required. The ADG1519 is a single-pole, double throw (SPDT) switch. An EN
5.
8-lead, 2 mm × 3 mm LFCSP (see the Outline Dimensions input on the lead frame chip scale package (LFCSP) is used to section). enable or disable the device. When disabled, the switch terminals (SA, SB, and D) are high impedance. The ADG1519 is fully specified at VDD = +5 V ± 10% and VSS = –4.5 V to –8.8 V for applications that require asymmetrical supplies. The ADG1519 on-resistance profile is flat over the full analog input range, ensuring excellent linearity and low distortion when switching audio signals. The construction ensures ultra low power dissipation, making the device ideally suited for portable and battery-powered instruments. The switch conducts equally well in both directions when on and has an input signal range that extends to the supplies. In the off condition, signal levels up to the supplies are blocked. The ADG1519 exhibits break-before-make switching action for use in multiplexer applications.
Rev. 0 DOCUMENT FEEDBACK
Information furnished by Analog Devices is believed to be accurate and reliable "as is". However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and
TECHNICAL SUPPORT
registered trademarks are the property of their respective owners. Document Outline Features Applications General Description Functional Block Diagram Product Highlights Specifications Dual Supply Continuous Current Per Channel, Sx or D Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology IDD ISS VD and VS RON RFLAT ON IS Off ID Off ID and IS On VINL VINH IINL and IINH CS Off CD Off CD and CS On CIN tON EN tOFF EN tTRANSITION TD Charge Injection Off Isolation Crosstalk Bandwidth Insertion Loss THD + N THD AC PSRR Applications Information Power Amplifier Gate Drive Power Supply Rails Power Supply Recommendations Outline Dimensions Ordering Guide Evaluation Boards
