Datasheet ADG1519 (Analog Devices) - 3
Description3.8 Ω On-Resistance, SPDT Switch
Pages / Page15 / 3 — ADG1519. SPECIFICATIONS. DUAL SUPPLY. Table 1. Parameter. 25°C. –40°C to …
File Format / SizePDF / 673 Kb
ADG1519. SPECIFICATIONS. DUAL SUPPLY. Table 1. Parameter. 25°C. –40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments. analog.com
ADG1519 SPECIFICATIONS DUAL SUPPLY Table 1 Parameter 25°C –40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments analog.com
link to page 10 link to page 4 link to page 4 link to page 4 link to page 10 link to page 4 link to page 4 link to page 10 link to page 4 link to page 4 link to page 10 link to page 4 link to page 4 link to page 4 link to page 4 link to page 10 link to page 4 link to page 4 link to page 10 link to page 4 link to page 4 link to page 10 link to page 4 link to page 4 link to page 10 link to page 4 link to page 10 link to page 4 link to page 4 link to page 4 link to page 11 link to page 4 link to page 11 link to page 4 link to page 11 link to page 4 link to page 4 link to page 4 link to page 4 Data Sheet
VDD = +5 V ± 10%, VSS = −4.5 V to −8.8 V, and GND = 0 V, unless otherwise noted.
Table 1. Parameter 25°C –40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH VDD = +4.5 V, VSS = −7.2 V Analog Signal Range VDD to VSS V On Resistance, RON 3.8 Ω typ VS = VSS to VDD, IS = −10 mA, and see Figure 181 5.2 6.2 7 Ω max On-Resistance Match Between 0.1 Ω typ VS = VSS to VDD, IS = −10 mA1 Channels, ∆RON 0.3 0.35 0.4 Ω max On-Resistance Flatness, RFLAT (ON) 1.15 Ω typ VS = VSS to VDD, IS = −10 mA1 1.6 1.85 2 Ω max LEAKAGE CURRENTS VDD = +5.5 V, VSS = −8.8 V Source Off Leakage, IS (Off) ±0.1 nA typ VS and VD = VDD – 1 V to VSS + 1 V, see Figure 191, 2 ±10 ±12 ±100 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS and VD = VDD – 1 V to VSS + 1 V, see Figure 191, 2 ±10 ±13 ±140 nA max Channel On Leakage, ID, IS (On) ±0.1 nA typ VS = VD = VDD – 1 V to VSS + 1 V, see Figure 201, 2 ±10 ±13 ±110 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, I 3 INL or IINH 0.001 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS VDD = +5 V, VSS = −8 V Transition Time, tTRANSITION 240 ns typ RL = 300 Ω, CL = 35 pF4 305 365 400 ns max VS = 3 V, see Figure 211 tON (EN) 215 ns typ RL = 300 Ω, CL = 35 pF4 275 325 360 ns max VS = 3 V, see Figure 231 tOFF (EN) 265 ns typ RL = 300 Ω, CL = 35 pF4 335 380 415 ns max VS = 3 V, see Figure 231 Break-Before-Make Time Delay, tD 65 ns typ RL = 300 Ω, CL = 35 pF4 38 ns min VSA = VSB = 3 V, see Figure 225 Charge Injection 12 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF, see Figure 241, 4, 6 Off Isolation –60 dB typ RL = 50 Ω, CL = 5 pF, frequency = 1 MHz, see Figure 254 Channel-to-Channel Crosstalk –60 dB typ RL = 50 Ω, CL = 5 pF, frequency = 1 MHz, see Figure 264 Total Harmonic Distortion Plus Noise, 0.001 % typ RL = 10 kΩ, 5 V p-p, frequency = 20 Hz to THD + N 20 kHz, see Figure 284 –100 dB typ Total Harmonic Distortion, THD –135 dB typ RL = 10 kΩ, 5 V p-p, frequency = 1 kHz4 –128 dB typ RL = 10 kΩ, 5 V p-p, frequency = 20 kHz4 –120 dB typ RL = 10 kΩ, 5 V p-p, frequency = 100 kHz4
analog.com Rev. 0 | 3 of 15
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Specifications Dual Supply Continuous Current Per Channel, Sx or D Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology IDD ISS VD and VS RON RFLAT ON IS Off ID Off ID and IS On VINL VINH IINL and IINH CS Off CD Off CD and CS On CIN tON EN tOFF EN tTRANSITION TD Charge Injection Off Isolation Crosstalk Bandwidth Insertion Loss THD + N THD AC PSRR Applications Information Power Amplifier Gate Drive Power Supply Rails Power Supply Recommendations Outline Dimensions Ordering Guide Evaluation Boards
